HP 730
A Man
04-05-2002 17:47:13
Can any one tell me the max HP you can get out of a 730 D that motor is stock thanks
DON
04-06-2002 12:26:40
 Re: HP 730 in reply to A Man, 04-05-2002 17:47:13
we used to run a 13 mm rack setting and get around 65-68 hp. any more on the rack just made smoke.Don
G Taylor
04-06-2002 18:57:09
 Re: Re: HP 730 in reply to DON, 04-06-2002 12:26:40
Stock would be 59 HP. More airflow with the low restriction aircleaner conversion will allow more fuel to burn. The straight exhaust stack just makes it louder unless the intake side is also opened up. Unless pulling keep it stock. For field work reduce the load or get a larger tractor.
