How to mask tires and rims ?
Frank-in-Tallahassee
04-05-2002 05:06:01
Folks:
I'm getting ready to paint a rim with tire mounted on it. Wondering if anyone has any tricks thay have used that might beat that time honored task of using masking tape and paper.
Open to any new ideas !
Thanks,
70D // 855
jCarroll
04-07-2002 07:10:48
 Re: How to mask tires and rims ? in reply to Frank-in-Tallahassee, 04-05-2002 05:06:01
I've tried masking tape, masking compound, and finally the metal roof flashing technique suggested by Rod. It's way and afar the best for me - quick, functional, durable, reusable.
If you don't need/want to remove the tires, this is a slick way to do a good job on the visible portion of the rim.
john
04-05-2002 21:23:54
Unbelievable!!!!! !!!! Get you a roll of double sided masking tape stick it as close as possible without getting ignorent all the way around the bead of the tire. Lay A pc. of plastic that covers the whole tire then take the handy ball peen hammer and tap it ever so gently all the way around the rim this will cut the shape out perfectly. You can then use it three more times w/o having to recut another pattern. MY GOODNESS.
ET
04-05-2002 19:29:00
It real amazes me to see what gets all the people
out with an opinion on this board.
04-06-2002 03:46:46
 Re: Re: How to mask tires and rims ? in reply to ET, 04-05-2002 19:29:00
ET:
Did you have an issue with my question ?
I appreciate all the different points of view. Proves there are more than one way to skin a cat.
Frank
ET
04-06-2002 04:25:27
 Re: Re: Re: How to mask tires and rims ? in reply to Frank-in-Tallahassee, 04-06-2002 03:46:46
No issue just amazed at the number of replies.
Mike
04-05-2002 15:14:25
Some good ideas but I still perfer to paint the rim with the tires off inside and out after sandblasting. Then mount tires on painted rims using new tubes. I consider this just part of a restoration . Anything less is just a paint job.
None Sense Patrol
04-06-2002 16:45:46
 Re: Re: How to mask tires and rims ? in reply to Mike, 04-05-2002 15:14:25
Youre stupid... he didnt ask what a restoration was he asked how to paint a mounted rim.... He could just be freshening the paint up a a little
Takes one to know one !!!
04-06-2002 18:44:41
 Re: Re: Re: How to mask tires and rims ? in reply to None Sense Patrol, 04-06-2002 16:45:46
HA! HA!
Clooney
04-05-2002 15:34:53
Mike, I have to agree with you. Painting the inside of the rims is part of the restoration process. ~I don't use a color coat anymore, just use epoxy primer as I have had problems with the tubes sticking to new paint.
~I always put new tubes in when they are apart, don't want to have to remove a tire on a new painted rim to replace a rotting tube.
mike
04-06-2002 04:10:04
 Re: Re: Re: How to mask tires and rims ? in reply to Clooney, 04-05-2002 15:34:53
I picked up tire talc powder from my tire dealer
and put it in a baby powder can and sprinkle on rim. this works to prevent sticking as I had to change
tires after doing this.
Correct Police
04-05-2002 16:25:29
If you realy want to do the restoration correctly your need to remove the tires and remove the rims. Throw them away and search the world over for new old stock rims. You need to make sure that the part numbers match up with serial number range of the tractor that you are restoring. Then you need to hire Anderson consulting to come out and do an audit on the Bill of materials showing that you did get the correct version of the rim. Then you need to hand sand all the paint off the rim making sure that you do not remove any manufacturing flaws that were originaly on the wheel such as a weld that was not ground down completely. If you by accident you do remove a manufacturing flaw then you need to get Anderson Consulting back out do an audit so that you can certify that this was an error. Then reweld the wheel and grind it down to exact match of the flaw that was Originaly there. Then you need to prime it with the exact same primer that was used when the tractor was MFG. No epoxy allowed. After priming back comes Anderson consulting and they document your procedures and then you can put the final coat on. Once the final coat is applied then have the tires remounted. If any scratching is done then for it to be a true restoration you need to start all over. If you do manage to remount the tires without damaging the paint you need to burn all documentation gained in the process because 99% of the people will never know or care.
THE Correct Police.
mike
04-06-2002 04:20:19
 Re: Re: Re: Re: How to mask tires and rims ? in reply to Correct Police, 04-05-2002 16:25:29
You've been busted ! I can tell you have never seen the inside of a rim as the factory never primed they put paint over bare metal. I just like to keep my rims from rusting from the inside out!! In my area calcium was almost always used mixed with a bad climate. The only way to get ride of it is to change tubes. I wish I had started working on tractors from the west from the get go here in the east they are lots rougher !!
F-I-T
04-06-2002 05:44:40
 Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to mike, 04-06-2002 04:20:19
Mike:
Have you ever changed a tire on a manure spreader in the winter ?
Now there's a tough one. We used to back the "A" rear wheel up on them to break the bead loose !
F-I-T
mike
04-06-2002 18:42:28
 Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to F-I-T, 04-06-2002 05:44:40
I have used a front end loader with down pressure to break loose the beads with good results. Or a hammer and a narrow blade chisel that I think was made for brick laying. Pretty resouresful for someone who's ,quote ,stupid,un quote.You better watch out changing the subject
or you will be the next one caught by the {stupid}
policer.
LJS
04-07-2002 01:19:30
 Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to mike, 04-06-2002 18:42:28
No one accused you of being stupid, don't take it so hard. Most all the post on these boards are meant in good hummer or to make a point. The point you made was that unless you took the tires off it was "just a painted job". I will give something to think about. I have an a gent that wants me to paint a old B for him. It was his fathers and he just passed away. The tractor is an early 40's model that had the battery behind the dash. Well like all of those models it was rusted to death. He took a hood off another year of B and converted it. He then made a bracket for the battery box to fit on the powertrol He has an alternator on it. The grill screens are not the best but it is good enough for him. He wants me to paint it but he does not want to pay for having everything tip top flawless shape. The tractor is nice solid good running condition. He did have the rims painted when he had the tires off. The rims are pitted badly on the outside so I can only imagine what the insides looked like. It needed painting on the inside! When painting the tractor he does not want pay to have me take the hood off and paint the underside of it. I would hate to tell him that because the underside of the hood will not be painted it will not be a restoration - thus a slap in the face and a disgrace to his fathers memory. Hey he is tickled to death with it as it is. Some might consider it a badly bastardized attempt at a restoration. I don't feel that way. He is restoring his fathers tractor in his memory and I am more than happy to help and support him in the way that he is doing it. I guess the whole point is that there are all kinds of levels of restoration. You can sink a whole bunch of money into something going through it from top to bottom replacing every seal. If you ever want to get that investment back out of it good luck, it can only be done if it is a rare one of a kind or low production number tractor like a 435 or a high crop 630. I have not seen where it add that much substantial value to the tractor to have things done in the restoration process that were not needed due to the fact that it condition of that component/seal/no rust problem on the rim did not merit the work.
I would much rather have one of each 530,630,730,830 that were marginal restorations than one 530 that had been completely disassembled, every component sandblast or hot tanks or cleaned to the bare metal and then had all of the best and most accurate rebuilding/painting etc. You would have that a truck load of money and time stuck in that 530 and where do you stop. I have sold 12 old tractors that I have been fixed up in the last year. All of them have been fixed up/restored to different levels. I have never listed one of them as restored. Restored is just to wide open. All the buyers were happy with what the purchased. Yes I would love to have a shed full of tractors that were just mint. But my pockets are not that deep. What I do have though I do consider to be restored, but I would never sell one of them that way because that is just my opinion. Yes I was the correct police post. The whole time I wrote it I was smiling and intended it in a friendly fashion of rib - joke. I wish you and every one else that might have been offend the best and keep up the good work because someday I am going to need one of those rims you painted.
LJS
LJS
04-07-2002 01:27:55
 Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to LJS, 04-07-2002 01:19:30
I take that back after reading the other post I seen that someone did accuse you of being stupid. It was not me. Laugh, smile a little. Don't get worked up about it.
LJS
Mike
04-07-2002 06:13:07
 Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to LJS, 04-07-2002 01:27:55
I'm not the one who got worked up until they started with school yard name calling.Before you don't paint the inside of the hood remember one thing two-cylinder gas,fuel tanks,almost always
are rusting or are allready rusted out on top. Could make for a disaster if someone decides to fill it up. For safety sake mainly on a rough rusted tractor as you discribed I would pull the tank out and check. Paint the tank do the hood if you want or not a hood doesn't make a tractor run but clean gas does. Just some points to ponder.
LJS
04-07-2002 12:00:00
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to Mike, 04-07-2002 06:13:07
Mike I agree on the rust issue, he had the hood off and had several parts tractors so I would assume it is free of debrie that would trap moisture and the tank is the best one he had and it is in reasonably good condition. From the bottom of the tank you can see he cleaned it well. He should of painted it when off no doubt about that but he is happy with the way it is going to be and does not want to pay me to do it so I am not going to argue that. I think this whole discussion thread is realy not about masking tires it is about what level of restoration a guy prefers. Some like to spread grease on the tire. I am sure the people doing this did not strip the rim of all paint, remove it from the cast center primer/wet sand to a fine finish material. They just cleaned the rim up good and shot some paint on it. That is ok with me if that is what they want for a finished product. As long as they are happy with it I am too. I might not want to have it myself or think as highly of it as they do. But that is ok, I am happy that they are happy and enjoy to visit with they about the common intrest of Green and Yellow paint.
Take care.
LJS
mike
04-07-2002 18:44:32
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to LJS, 04-07-2002 12:00:00
LJS; I did find your story of the correct police funny and in good humor,well written. I only wish I was better at phrasing things
and typing with brain in gear.
lets keep it simple
04-05-2002 21:45:04
It's like everybody says, opinions are like ***holes, everybody has to deal with their own.
Clooney
04-05-2002 17:04:51
LJS, thanks for the interesting view through the eyes of the "correct police"
PK
04-05-2002 17:58:02
 Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to Clooney, 04-05-2002 17:04:51
Use 3 inch masking tape , cover the tire overlapping the rim a little, take a good sharpe utility knife and trim the tape from rim and paint it , it will come out good.
04-05-2002 16:18:42
Guys:
I understand what you are saying, but I also know that in the six months I have been working on this project, I have never used the term restoration.
I'm rebuilding and or refurbishing this tractor and hope it's green where it's supposed to be, and yellow where it's supposed to be, with no oil dripping, spewing, spraying, or burning.
It might get new tires, but that will probably be way down the road. The rims were painted inside when I put those tires on it in 1971. No fluid since, new tubes with the tires.
I'll probably have it scratched and nicked here and there before too long, but I intend to have a great time listening to it do the little bit if work I'll have for it. The next project is to rebuild the 45W loader for it now laying out in the yard.
BTW, Clooney, several puffs of baby power in the tire, and it won't stick to the paint.
Thanks for the tip on the DuPont code. I bought some today, and so far I think it will do just fine.
70D // 855
Rod
04-05-2002 13:46:25
LJS has the best idea. I actually went to a lumber yard and got galvanized shingles that are 5 x 9 and have a mild convex to them. Let the air out of the tires and took a rubber mallet and tapped them in all the way around on both tires, both sides. looked like a windmill wheel. Painted the wheels and had no overspray on tires.The next day I took tire paint and painted the tires reaching down behind the metal with the brush, it kept the black paint from touching the yellow wheel. The metal strips protrude out away from the tire so that keeps over spray away and lets you get right behind with the black paint. Took about 5 min to put them on with the wife handing them to me. The cost was $20 for a bundle that let me do all 4 tires on a tractor. I dont think there is anything that could do a better job this easy. just a thought.
04-07-2002 09:54:34
 Re: Re: How to mask tires and rims ? in reply to Rod, 04-05-2002 13:46:25
Rod:
I looked but could not find galvanized roof shingles. Where did you find them ? Any national chain store hopefully ?
Frank
Dan in Oregon
04-05-2002 12:16:25
I just painted an F-12 Farmall. What I did and it worked quite well was took a large sheet of Kraft paper and held it up against the tire. Next I stapled the paper to the tire just outside of the edge of the rim. Once thr paper was all stapled in place, I took a razor knife and cut around the rim. If you use 1/4" or 5/16" staples you shouldn't have any problem. If you puncture a tire and tube with 5/16" staples, then you have some real problems.
JD
04-05-2002 10:52:28
Plastic works well for me Just take a large enough piece to cover the tire and cut out a circle the diameter of the rim. Deflate the tire and work the plastic into the bead. Inflate and paint. This way you have the whole tire covered and no overspray can get on the tires.
Glen Rusling
04-05-2002 15:28:32
 Re: Re: How to mask tires and rims ? in reply to JD, 04-05-2002 10:52:28
I take a can of grease and a paint brush and paint the rubber tire. If some gets on rim I use varsol to remove the grease carefully. Then I just paint the rim. When the paint is real dry I wash the tire off with a power washer. Voila.
Works good for me.
poorerbut
04-05-2002 11:58:34
I use the plastic, too. Been doing it that way for
many years. Only difference is that I made a
bunch of little aluminum triangles to hold the
plastic away from the rim when I can't break the
bead away . Works on fronts, rears, implements.
I cut the diameter a little on the small size
and then stretch it over the rim . pb
JD
04-05-2002 12:12:02
 Re: Re: Re: How to mask tires and rims ? in reply to poorerbut, 04-05-2002 11:58:34
I meant to say that you need to cut it a little smaller and stretch it over. If you leave the plastic large enough you can pull it tight over the tread and fasten it to the tire, I use tape, this holds it away from the rim and covers the tire. Has been working well for many years for me also. Joel
F-I-T
04-05-2002 12:40:13
 Re: Re: Re: Re: How to mask tires and rims ? in reply to JD, 04-05-2002 12:12:02
JD:
You mean like a good quality drop cloth plastic sheet ?
F-I-T
JD
04-05-2002 14:16:44
 Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to F-I-T, 04-05-2002 12:40:13
F-I-T you want something that is strong enough that it won't tear but something that's not to heavy that it's bulky to work with. Good Luck, Joel
poorerbut
04-05-2002 13:30:49
That should work. I buy 4 mil and 6 mil poly for
vapor barior under concrete . Usually 20' x 100'
rolls . Local tractor, hardware, etc stock it.
Last case I bought from Lowe's. Can't remember
the exact price, something like $ 0.00745 / s.f.
Later. pb
LJS
04-05-2002 08:31:51
Frank
I have painted 8 tractors in the last year and have tried all the tricks listed on this web site and rummys. This is what I have found to work the best for a truly show quality job with out removing the tire from the rim. Get some flashing tin 8"-10" wide. Cut it into 10" lengths for rear tires and 6" or shorter lengths for smaller diameter front tires. Deflate the tire until you can slide the flashing in 1/4"-1/2' between the tire and the rim and not so far in you puncture the tube. Place flashing around wheel on both side and inflate tire to hold the flashing firmly in place.
The advantages I find in this approach is
1. Quick Installation time, once the tin is cut it takes less than five minutes to mask a rear tire on a tractor. I have a box of tin that is cut and I just pull the box out and with in minutes I have the tire masked and masked well.
2. You can wet sand after installation to the tin masking. With masking tape if you need to wet sand you either end up with water in your paint due to the fact it held up in between tape somewhere, or reinstalling the masking tape. With the tin you can wet sand wash it down with a hose, then blow it off with and air hose and a little drying time you are ready to paint again.
3. Painting the lip of the rim. The tin makes a nice backdrop and you can spray at any angle you want and not worry about over spray on the side of the tire.
4. Clean up of over spray, there is little to no over spay on the tries and if there is you an work on it with solvent without worrying about it getting on the paint due to the fact the tin acts a shield. When I used the method of masking back 2" with masking tape and then cleaning any over spray of after you painted. I always ended up with a little dirt of some lacquer thinner getting on the new paint and off course the whole time you are cleaning that over spray you are just making more dust that gets on that finish you worked so hard to get that is not dry yet.
5. Removeval- Once the paint has dried, deflate tire, remove tin and re inflate. You are done in minutes and you do not have tape stuck to the bottom of your shoe.
6. Re usable- If you are going to paint more than one tractor this works great.
If you are just painting a tractor that is going to be back in the field next week, I would use the paint it and clean it up after with solvent trick. But if this is something you want to look like it just rolled of the factory. This is the way to go I feel. Take a look at some of the tractors I have painted by using the link below or going to photos on this site and then searching for Stallbaumer. I am learning with each one and people on this board have helped me greatly.
LJS
LJS
04-07-2002 03:01:24
 Re: Re: How to mask tires and rims ? in reply to LJS, 04-05-2002 08:31:51
Another reason
It is real hard to roll a 38" tire around with masking tape and plastic wraped around it without it comming off plus wet sanding just dont work with masking tape and plastic.
With the flashing you put it in and you can prime/wet sand/finish coat and roll it to town an back and never have to screw with the masking becuase it fell off or has water or sanding dust traped in it.
I am not trying to tell anyone that another way is wrong. I have tried everything from grease to the best masking tape and plastic in the last year. This realy worked exceptionaly well for me on this last project.
Enough said I will leave the issue rest.
LJS
04-05-2002 08:52:36
LJS:
Great ideas, and great looking Tractors !
What paint did you use ?
I'm especially interested in the yellow. My PPG dealer can't even come close to my original quart of JD leaded paint. I know that's the right color for me, but I'm at a loss.
I like the idea of the flashing, I just have to go find some.
Thanks for you reply !
70D // 855
LJS
04-05-2002 09:08:51
 Re: Re: Re: How to mask tires and rims ? in reply to Frank-in-Tallahassee, 04-05-2002 08:52:36
I am still using the JD Synthetic Enamel with NAPA 8010 hardener. I have been talking with some people in the body shop business. Everyone has an opinion and I have not decide who is right for me and my equipment/facilities, so I have not come up with a solid next move on paint types to use on the next project. I have been watching your post and looks like you will have a real top of the line show piece. This painting is some tricking and dangerous stuff. The only thing that scares me about some of the paints in the toxic nature. Even the NAPA 8010 harder is some nasty stuff. So I have been for the moment sticking with the JD paint that I have good luck with but I plan on moving on when I have the equipment and the knowledge to do so. I would like to get to the point that I could shoot some of the best green paint in country but I need a paint booth and I am currently working on that. So until I get the booth, a positive pressure air mask system, and a better finish paint gun I a going to stick with the Synthetic Enamel. At least that is what I think today, someone could come along and convince me differently. That is what I like about these websites.
LJS
F-I-T
04-05-2002 11:52:59
 Re: Re: Re: Re: How to mask tires and rims ? in reply to LJS, 04-05-2002 09:08:51
LJS:
Thanks for the info.
I doubt mine will be a show piece, I'm just trying to get everything green ! so far the acrylic enamel has been pretty easy to work with. I use a respirator, and have a fresh air system, too. I have to paint in small amounts in a confined garage area, and that really hampers the progress, since I'm doing continous mechanical repairs along with layer by layer of painting. I hope to build a shop next year. I'm going to have to clean very well before I can put on the finish coats of green on the entire tractor.
I did find the yellow today, but I had to go with Dupont, which is alright with me...it's cheaper, too !
Maybe I can get that wheel center yellow tomorrow...weather is supposed to be great.
F-I-T
Clooney
04-05-2002 15:29:09
 Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to F-I-T, 04-05-2002 11:52:59
Frank, what Dupont number & tint did you end up with?
Paint code
04-05-2002 16:23:24
 Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to Clooney, 04-05-2002 15:29:09
Clooney:
They mixed some of the 2612 in acrylic enamel (their computer says it's a Dodge truck color ), and I put a few drips on the outside of a laquer thinner can I had primed with epoxy, buff, then the leaded yellow from JD.
It looks verrrrry close to me, and so I bought two quarts, and have the first two coats on the wheel center.
I'll take another look at it tomorrow, and see if the color is acceptable. I think it will be.
Frank-i-T
Clooney
04-05-2002 16:41:41
 Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to Paint code, 04-05-2002 16:23:24
Frank, I think you will find that 2612 becomes a nice deep looking yellow that looks fantastic in the sun.....
Picture of the DuPont paint
04-05-2002 17:07:42
 Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to Clooney, 04-05-2002 16:41:41
third party image
Digital images aren't always the best regarding color.
If you look at the right upper edge, you'll see my daughter's new Belgian, and two of her paints.
Who said old tractors are the only expensive hobby !
F-I-T
F-I-T
04-05-2002 16:58:26
Clooney:
I just went out and checked it, and it's looking pretty nice.
It'll get a lot of sun down here. I hope it holds up good as far as bleaching. Most of the yellows turn kind of white in a realtively short time.
It's got two good coats on it...probably too heavy on the second coat...it just about started to run, so I stoppped, and figured if it needed more it would have to be tomorrow.
I'm really learning alot about the different temperatures of the reducers !
F-I-T
Clooney
04-05-2002 17:14:10
 Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to F-I-T, 04-05-2002 16:58:26
Frank, if you are painting in the sun set your reducer temp closer to the metal temperature & not the ambient temperature. It probably doesn't make much difference on a cast wheel but will effect the way the paint lays down on sheet metal.
F-I-T
04-05-2002 17:48:01
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to Clooney, 04-05-2002 17:14:10
Clooney:
One of the problems I see is that this PPG reducer doesn't give a temperature range anywhere on the can. The guys just sell me what they think I should be using depending on the general weather in the forecast. By now I have about three different types.
Maybe I should ask for a pamphlet that describes the reducer's operating range.
H-m-m-m-m-m-m-m-m...?
F-I-T
Clooney
04-06-2002 05:32:08
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to F-I-T, 04-05-2002 17:48:01
Frank, I don't currently use PPG reducers. What series reducer are you using? I have some charts for the DTR series & probably have something on the others (somewhere).
F-I-T
04-06-2002 05:54:34
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to Clooney, 04-06-2002 05:32:08
Cloney:
DTR series, # 601, 602, and 604...called Cool, Medium, Hot temperatures. I went to a page with PPG msds's and product sheets, but those boiling points seemed awful high. Like Cool was 83* and up, and Medium and Hot were both 133* and up.
They are described as Cool shop, Normal Shop and Heated shop.
F-I-T
Poor Farm Jim
04-06-2002 07:45:12
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to F-I-T, 04-06-2002 05:54:34
Frank, this is off the PPG Product Information Sheet for the Acrylic enamels:
DTR 600 (50-65 degrees F.)
DTR 601 (60-75)
DTR 602 (70-85)
DTR 604 (85 and above)
Yes, the newer cans just call them cool, medium and hot, but I still have an older can of 602 and it also says that is for overall painting and that for spot/panel repair the 602 is for 85 degrees and above. It also is printed in French if you are interested.
Jim
F-I-T
04-06-2002 10:57:54
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How to mask tires and rims ? in reply to Poor Farm Jim, 04-06-2002 07:45:12
Thank you Sir !
That's what I've been needing.
I better gripe at my buddy and get him to cough up some tech sheets for me.
Yeah, these new cans of mine are in French, too. They must add it to their wine...
Thanks again Jim.
F-I-T
LJS
04-05-2002 08:48:47
This is where Idea of flashing tin came from for me. See link below
Binder-man
04-05-2002 08:02:28
What do you mean about timely task of paper and masking tape?? Use a good grade of tape, like 3M,and newspaper, in a matter of minutes you are done!!
Binder-Man
LJS
04-05-2002 08:42:41
 Re: Re: How to mask tires and rims ? in reply to Binder-man, 04-05-2002 08:02:28
Both sides of 4 tractor tires, maybe 20-30 minnutes if you realy hustle. Then you find a spot you need to sand some more on, can I wash the rims down without getting the paper wet. What If I do not get it painted that day that you installed the masking and it sits for a week, Can I wash it down to remove any dust that settled on the rim that week or am I limited to blowing it off, and when I blow the dust off will the paper go with it?
Just things to think about.
04-05-2002 08:26:17
Binder-man:
I didn't say timely, I said time-honored, meaning the most prevalent method practiced in the past.
You must be pretty good at masking tires, because if I could be done in a few minnutes, I'd be there. I just dread the thought of masking 38" tires.
I'll probably have to do it that way anyway, but there are some interesting ideas coming out here, and I appreciate all of them.
Now if I could just find the right shade of yellow !
Thanks !
70D // 855
John F
04-05-2002 06:24:47
Frank:
I deflated the tire, used a putty knife to simply push news paper between the tire and rim. After your done one side remove the paper, flip it over and repeat.
Norman
04-05-2002 05:45:54
Frank, I take a piece of light gage sheet metal about 25 or 30 inches by 15 to 20 inches and cut a radius the same as the rim. The front tires will be smaller. I have cut one for every size tire I paint. You can hold it and paint by your self but it is a lot easier to have some one hold it for you. Be sure and use all safty precautions. Later
Norman
farmuse
04-05-2002 05:30:04
Have not tried it myself, but I have heard of people coating them with grease and then preasure washing them after the paint
Mike F
04-05-2002 06:26:55
 Re: Re: How to mask tires and rims ? in reply to farmuse, 04-05-2002 05:30:04
I still use 2" masking tape. The way I do it is just put the tape on to cover the rim and tire and keep overlapping the tape, then trim it off tight to the rim with a razor blade. I paint my wheels with a touch up gun and that way it minimizes the overspray. Then wet down a cloth with naptha, thinner and wipe the overspray away once the tape is removed, this even works if using hardener, the key is before you tape it, make sure you wipe the whole tire off with naptha , this way the paint won't stay on.
