53 jd mod 50
scott bartholom
04-04-2002 12:13:20
I have just bought a mod 50 and it runs great. I have flushed the tranny and all other fluids. I was able to disengage the power shaft but cant reengage it. The shift lever seems to be stuck. its loose but seems jambed or some thing. cant get it to engage.
ET
04-05-2002 06:36:49
 Re: 53 jd mod 50 in reply to scott bartholomew, 04-04-2002 12:13:20
You might need to bump the engine with the starter to align the gears so it will go in gear.
bart
04-05-2002 11:27:22
 Re: Re: 53 jd mod 50 in reply to ET, 04-05-2002 06:36:49
instead of bumping with starter can i rotate the clutch????
ET
04-05-2002 12:53:12
 Re: Re: Re: 53 jd mod 50 in reply to bart, 04-05-2002 11:27:22
If it is a live pto you need to turn the crankshaft. You can engage the clutch and do it by hand if you are tough. If its a trans. driven pto you can just turn the clutch.
bart
04-06-2002 11:42:35
 Re: Re: Re: Re: 53 jd mod 50 in reply to ET, 04-05-2002 12:53:12
ok i have tryed everything but cant get the lever to engage. Can i get to the linkage if i take of the shifting housing????
Walt F
04-04-2002 20:09:56
Are you trying to engage it while the engine is running? If it's got a live p.t.o., i believe you can only engage it when the engine is still (the lever to the left of your right foot). If it's not got a live p.t.o., then you can engage it when you disengage the clutch.
