G-MAN
04-03-2002 20:01:55
Hi guys, we had a little informal training session tonite - put on by a guy that just came back from Twenty Series school. After the meeting, I took an 8520 for a spin around the section. I have got to say, if that tractor is the future of Deere, the future looks bright. This tractor is equipped with the Independent Link Suspension (standard on the 8520) and the Active-Seat. I can't believe how well this tractor rides and handles. I'm not trying to start another brand war here (this is the JD board after all, and I had enough of that on the Pulling board), but this tractor simply leaves everything else in the dust, as far as comfort, power, lighting, etc. If you find yourself at your JD dealer, and they have an 8000 Twenty, beg, borrow, or steal a test drive. Especially if the tractor has ILS and Active-Seat, otherwise you may not notice a huge difference from the 8000/8000 Ten Series tractors, besides the styling. However, the Twenty series makes standard a lot of features that were optional on the Ten series, so the net price increase from a 8410 to a 8420 is only about 3%. The ILS gives true front differential lock-up instead of limited-slip, which obviously makes the tractor a true four-wheel drive, not just a front-wheel assist. The 8520 is actually more powerful and will outperform a 9120 in the field. Before anyone jumps me for that, row-crop tractors are rated at the PTO, 4wds are rated at the flywheel, hence the horsepower advantage. An 8520 fully loaded also weighs close to or more than a 9120. The High-Intensity Discharge lighting package is tremendous (just like the white headlights on cars). Do not look into the lights, they will flat out blind you. I turned them on on a back street and signs a half-mile ahead were lit up bright as day. Anyway, sorry for the long post. I just wanted everyone to know how impressive these machines are. And to you true JD fans, don't listen to the naysayers, JD is still the top of the heap in the ag market, regardless of what the profit numbers say.
