45 combine starter needed
TJsdad
12-09-2003 20:01:21
Can anybody tell me where to get a starter for a 1963 45 combine?
tom
12-11-2003 04:27:55
 Re: 45 combine starter needed in reply to TJsdad, 12-09-2003 20:01:21
i have a used one
Todd Smith
12-10-2003 04:42:54
I believe that the starter for the model 45 is the same for the 2010. Make sure it is the gas model though.
MIKE HANLEY
12-09-2003 22:01:37
Not 100% here, but I seem to recall that the starter, generator and dist parts for the 45 combine were listed as the same with some JD tractor of that era in aftermarket catalogs in years past. Maybe your JD dealer should be able to help with the part number and then cross check with the tractors of that era. That would expand your options. Do you have the old one? Even without a tag a GOOD rebuilding shop should be able to ID the old caseing and fix you right up. You'd be surprized on how the guy we work with for our stuff can fix up old stuff that is in 50, 60 year old construction equipment, old semi's and farm stuff.
MIKE HANLEY
12-09-2003 22:01:02
Not 100% here, but I seem to recall that the starter, generator and dist parts for the 45 combine were listed as the same with some JD tractor of that era in aftermarket catalogs in years past. Maybe your JD dealer should be able to help with the part number and then cross check with the tractors of that era. That would expand your options. Do you have the old one? Even without a tag a GOOD rebuilding shop should be able to ID the old caseing and fix you right up. You'd be surprized on how the guy we work with for our stuff can fix up old stuff that is in 50 50 year old construction equipment, old semi's and farm stuff.
MIKE HANLEY
12-09-2003 22:04:22
 Re: Re: 45 combine starter needed in reply to MIKE HANLEY, 12-09-2003 22:01:02
Sorry for the double posting. Hit back space to make a correction and thought I made it in time. Guess I didn't.
Jake
12-09-2003 21:51:47
I have a good one here. Email me for details.
