51 a fan
bob.s
04-03-2002 15:41:27
how do I remove the pulley from the fan shaft. looks like some kind of spring clip on the splened shaft. and is ther a double pulley that I can pout on to run my power stearing ? thanks.
Frank-in-Tallahassee
04-03-2002 15:57:03
 Re: 51 a fan in reply to bob.s, 04-03-2002 15:41:27
third party image
bob s.:
you'll have to press down on the fron fan clutch cup, down against the spring. Then you tap that little collar down and the two keepers (sort of like valve keepers) can be removed.
If they've been on there for some time, they might need some persuading. You might want to renew the fan clutch disks while you're in there.
70D // 855
Bozo
04-03-2002 18:59:09
 Re: Re: 51 a fan in reply to Frank-in-Tallahassee, 04-03-2002 15:57:03
Just did this with help of a 2 cyl mechanic on my A. One of the fiber disks (#4) in Frank's diagram was completely disintegrated. Every once in a while (at idle)it sounded like the fan was hitting the shroud. Pulled the gas tank, fan shaft and gov. housing. Ground the valves and honed the cylinders (worn less than 0.10). Started the tractor for the first time yesterday and retorqued the head. Idles as smooth as silk.
F-I-T
04-03-2002 19:55:50
 Re: Re: Re: 51 a fan in reply to Bozo, 04-03-2002 18:59:09
Bozo:
Sometime when the facings would go bad, some people would drill a hole though the assembly, and bolt it up tight. It would really be quiet, until the fan shaft bevel drive gear would be worn out in a few months from the chomping of the gears at start up ! That clutch really absorbs a bunch of pulses when the engine starts.
That's a nasty job for no more than you have to replace isn't it ? But I'm glad it's smooth for you now !
F-I-T
