4320 PTO
JB
04-03-2002 11:00:05
My 4320 PTO does not stay in with out tying it
with wire, what am I looking at to fix this
problem Thanks John
JB
04-03-2002 20:53:30
 Re: 4320 PTO in reply to JB, 04-03-2002 11:00:05
RE. 4230 Thanks to all for the help. It looks like I'll try Dave W's ideas and go from there
Bob W
04-03-2002 17:29:47
If the linkage checks out as directed by the other posts,the problem is likley the aluminum arm that engages the lock piston in the valve housing. The traction/pto shift valve assembly will have to come off the side of the transmission. Once it is off, there is a tin cover held on with a small screw. Under this coveris the linkage including the arm. They will bend or crack changing the profile and the lock piston does not go fully into the detent position. It is a relativly easy and inexpensive fix. You will need the arm, a gasket(valve housing to transmission) and 6 or 8 o-rings for the stand pipes that route the oil from thevalve to the clutches. lol, Bob
WTW
04-04-2002 08:23:10
 Re: Re: 4320 PTO in reply to Bob W, 04-03-2002 17:29:47
Bob, When referring to a Quad range or a Syncrorange transmission, your suggestion would be absolutely right but a Power shift is different as it does not have the cast aluminum arm or lock engaging piston that you referred to. I would say I have to agree that I have seen this problem on the 30 series and newer non power shift transmissions allot and you are correct when refering to those. Dave W.
WTW (4230)
04-03-2002 13:32:46
JB, Now that we are talking about a 4230 Power shift, remove the square floor plate that the dimmer switch comes through. Locate the PTO lever control rod coming down from the PTO lever and follow it down to the top of the clutch housing where it is connected to a short control arm. Good chance you will find allot of dirt built up on top of the clutch housing that is limiting the control arm from traveling clear down which is the ON position of the PTO lever. Dirt will be packed in this area and will need to be scratched loose and removed from this area. After getting this area cleaned up check the control arm for being tight on the control shaft. This arm has two flats that key it to the control shaft that it turns and is prone to work loose on the control shaft wearing the arm and sometimes even the shaft. The arm is held on the control shaft by 1/4" flange nut. This nut will work loose and cause the arm to become loose on the shaft and wear. The wear and lost motion results in partial engagement of the PTO control valve. See what you learn and let us know what you find. Good Luck Dave W.
ABSOLUTELY RIGHT WTW, WE SEE CORN COBS GET DOWN THERE AND BLOCK IT OCCASIONALLY, G-MAN
04-03-2002 14:47:32
 Re: Re: 4320 PTO in reply to WTW (4230), 04-03-2002 13:32:46
nt
G-MAN
04-03-2002 11:06:34
JB, is your tractor a synchro-range or a powershift? They used different systems depending on the transmission type. Repost and I'll pull the service manual and see if I can give you some pointers, if no one else responds before I get back to the shop.
JB
04-03-2002 11:30:42
 Re: Re: 4320 PTO in reply to G-MAN, 04-03-2002 11:06:34
I'm not having a good eye day, it is a 4230
and is powershift Thanks John
SORRY ABOUT THE SHORT POST, I HAVE A SERVICE CALL, WILL POST MORE LATER G-MAN
04-03-2002 13:04:29
 Re: Re: Re: 4320 PTO in reply to JB, 04-03-2002 11:30:42
G-MAN
04-03-2002 13:01:24
Right off the top of my head, I would look for a problem in the PTO/cluctch valve. There is a mechanism in there to use oil pressure to keep the PTO lever engaged - it sometimes gives problems. Get a service manual, as the procedure for removing and repairing that can be a little involved.
