Drawbacks on Aluminum Pistons?
TireD
12-09-2003 18:00:31
I have been seriously contemplating boring the block on my styled D and putting in a set of new aluminum pistons. It uses little oil and runs fine, but I'd like a little more power and less crankcase pressure than it has now. Can I still expect it to idle normal and run smooth? I have heard horror stories about vibrations, and not being able to idle under 500 RPM with A's and G's that had higher compression aluminum pistons installed. Does anyone have experience with this? All help is appreciated.
G-MAN
12-10-2003 07:42:09
 Re: Drawbacks on Aluminum Pistons? in reply to TireD, 12-09-2003 18:00:31
It will probably tend to vibrate a bit more, because the the balance of the rotating/reciprocating assembly will be off, but it shouldn't be too severe, and we all know that two-cylinders aren't exactly smooth to start with.
Charles
12-09-2003 19:00:19
I have 47 D LP with Alum. Pistons that idle on 250, on vibrations!
Crazyktmmatt
12-22-2003 23:12:07
 Re: Re: Drawbacks on Aluminum Pistons? in reply to Charles, 12-09-2003 19:00:19
How fesible would it be to take the crank out and have it balanced?
