3020 Coil
C Meyer
04-02-2002 17:20:46
Does anyone know what the resistance value on a 3020 coil should be? Hot and cold?
Clooney
04-02-2002 17:50:50
 Re: 3020 Coil in reply to C Meyer, 04-02-2002 17:20:46
C Meyer, if you don't get anything else to work with. (primary_.5-2 ohm) & (secondary_10,000-15,000 ohm). Those are just general auto coil specs & shouldn't be too far different on a tractor I wouldn't think. ~If yours are close it is probably good, if yours are way different your coils is either bad or the specs I gave you won't work. The primary is measured terminal to terminal & the secondary is measured from either terminal to the center tower.
