Primer
abe
04-02-2002 14:15:55
decided to paint my g with john deere paint.
is it adviseable to use primer? and what
kind do you suggest!! i am new to painting
but was very surprised with my results.
thank you abe
JH
04-06-2002 16:20:10
 Re: primer in reply to abe, 04-02-2002 14:15:55
I use Rustoleum. Works well with JD Classic Green
Mikey G
04-03-2002 13:29:21
I have painted 2 JD's using Sherwin willams Ultra fill primer it helps fill the pits in the old metal, sands well and stays on even when the carb drips and the color coat comes of the primer is still on and well bonded to the metal.I get mine at the car quest auto parts store.
Good luck
Mikey G
Larry E
04-02-2002 16:16:31
i used no primer,directions said nothing about it.Has been two years and still looks good.
Larry E
04-02-2002 16:20:06
 Re: Re: primer in reply to Larry E, 04-02-2002 16:16:31
I used no primer ,directions said nothing about it. still looks good after two years.
Green to the Core
04-02-2002 15:38:23
Abe, I suggest using the John Deere Primer, I know its a little more expensive than others but it has always worked good for me. One time I used some stuff from an Auto part store and the first coat of paint bubbled up on me, OUCH, so from then on I always used JD primer. I guess there was some kind of chemical reaction, ever happen to anyone else.
