2955 hydraulic problems
DSSmith
05-15-2006 21:24:26
I have bought a 2955, that has the return line on the hydraulic plugged with a bolt. When the return line is unplugged the powersteering quites working and the pto comes on. The remotes are not functing unless this line is unplugged. A little help please. Thanks, Shawn
Tx Jim
05-16-2006 04:38:05
 Re: 2955 hydraulic problems in reply to DSSmith, 05-15-2006 21:24:26
Shawn,are the remotes factory or aftermarket? If factory installed, remotes should have a short return hose between them and rockshaft housing. If remotes are leaking internally or are for open-center hyd's then they could cause your problem. Tx Jim
