JD 4010 Hydraulic Question
Zamzow
12-09-2003 12:47:30
My lever on the dash that controls the remote cyliner operation has gotten stiff. In fact, I can pull the lever down but not up. Is there a convenient trick to getting this going again without taking that controller box all apart? It wasn't too long ago when it worked. The tractor is used frequently, but not that function. Please help. Thanks.
JimKS
12-10-2003 18:26:41
 Re: JD 4010 Hydraulic Question in reply to Zamzow, 12-09-2003 12:47:30
Those aren't too hard to tinker with if you've done them before or have a good step-by-step manual, but if you've never had one apart, and you don't have a good manual, you'd be better off removing that valve assembly and dropping it off at a dealer.
DON
12-10-2003 12:02:04
IF IT IS THE REMOTE CYL . LEVER THEN PROBABLY ,INSIDE THE VALVE BOX, UNDER THE CAM, THERE IS A ROLLER ON EACH OF THE 4 VALVES. THIS ROLLER IS HELD IN BY A PIN (PRESS FIT) AND IT HAS PROBABLY WORKED OUT SO THE VALVE WONT GO IN THE HOLE HOLDING THE LEVER FROM GOING UP. IF IT IS THE ROCKSHAFT LEVER, THEN THE CABLE ON THE VALVE ARM IS FROZE AND THE CABLE HAS BENT UNDER THE DASH.
Zamzow
12-10-2003 14:22:14
 Re: Re: JD 4010 Hydraulic Question in reply to DON, 12-10-2003 12:02:04
Don, so how hard is it to get to this roller pin? Do you start just taking the valve box off/apart?
John
12-09-2003 18:10:36
Hate to say it, but the problem about has to be in the valve unless something in the linkage is restricting the movement.
