3020 weight.
Pruett
03-30-2002 07:01:45
Does anyone know about what does a 3020 diesel weigh? Without fluid in the rears?
Next question, is there any good websites that would give spec's (like the weight) so that I can just go to the site and find it?
Thanks in advance
Pruett
BIG JOHN
03-31-2002 06:10:54
 Re: 3020 weight. in reply to Pruett, 03-30-2002 07:01:45
I can fax all info. ballast depends on wheel option size- mine filled 15-5 38's go for 830 pounds per wheel. front weights weigh 85 pounds each, this includes sides. mine has side and one front weight. all together it tipped the scale at 9315 lbs. tractor alone row crop 7399lbs diesel and gas is 7203lbs--- standard diesel 7692lbs , standard gas 7496lbs.
CDH
03-31-2002 03:22:27
Hi Pruett try this site www.geocities.Heartland/acres/4901/3020.html later CDH
Steven M
03-30-2002 07:23:02
Shipping weight 3020 Diesel
7,360 pounds Add 260 pounds for Power Shift. Add 250 pounds for regular adjustable front axle.
