J.D. 60 Rock shaft.
Bill Shaver
03-29-2002 13:52:17
Gentlemen.
Does any of you have the idea of how to free-up an immovable rockshaft on my jd 60??? Hydraulics check out okay, have additional plugs for the powertrol block, but are too long can they be cut to fit??? One of them does have an adjustable orifice.
the ones currently in place are unadjustable & have hole drilled through them.
thank you, Bill Shaver.
Randy
03-29-2002 17:23:02
 Re: J.D. 60 Rock shaft. in reply to Bill Shaver, 03-29-2002 13:52:17
The ones with the holes will work to run both the rock shafts and outlets, When you have something plug into the outlets they if not the rock shafts should work. There is an adjustment screw that you can close down or shut down the rock shaft on the side, this was my problem on my 60
