Compression Check
50man
03-29-2002 03:09:18
What's the proper way to check the compression in a 2 cylinder? Also will I need a special adapter to fit the larger plug hole as I'm sure any tester I'll get is probably made for auto plugs?
Jack
03-29-2002 07:11:25
 Re: Compression Check in reply to 50man, 03-29-2002 03:09:18
My tester has an o-ring on it and it fits big holes and the small ones.Pull both plugs out and install the compression checker into no 1 cylinder.Pull the coil wire off(just for safty).Open the throttle up and hit the starter.After a few revolutions of the crank you should have a good idea if what you have and you can move on to number two.Hope this helps.Jack(TN).
Tractor 1
03-29-2002 19:16:39
 Re: Re: Compression Check in reply to Jack, 03-29-2002 07:11:25
50man, The compression on a new engine with rings seated should be 120 P.S.I. @200 R.P.M.(cranking speed) with throttle wide open. Pressures should not vary more then 10 pounds between cylinders at any time. Fifty Fan.
50man
03-29-2002 17:50:20
Thanks for your help.Any idea how much compression I should look for on a 50?
Jack
03-30-2002 07:37:54
 Re: Re: Re: Compression Check in reply to 50man, 03-29-2002 17:50:20
100 to 125 would be ideal for stock pulling.My friends 50 has 125 psi and pulls good in the 5500lb class.Let us know how it turns out.Later,Jack.
