Follow-up info re. 1948 JD B (knocking)
tim hinton
03-28-2002 18:59:18
it doesent sound like a rod it kinda goes away if you push foward on the clutch handle. we took the flywheel off today (the flywheel pretty loose on the crank.can this be shimed to fit the splines better? thats only part of the problem) behind the flywheel there is a cover. behind the cover is a fancy bushing-seal-thrust washer (all the same part) the thrust washer part has a sprial grove in it (to cary oil to the bushing?) the inner end (thrust side) is worn and where it rubs the crank bearing holder is worn. is that (part) thrust bearing-bushing-seal avalable? ?$ and do i need a new left side crank bearing holder? or can all of that be shimed? i hope i explaned every thing well enough. thanks for all the great help i have been getting.tim
Steven M
03-28-2002 19:26:03
 Re: follow-up info re. 1948 JD B (knocking) in reply to tim hinton, 03-28-2002 18:59:18
One thing you can do to keep the flywheel tight is to use Loctite.
