JD 3010 carb problems
Jeff Singletary
12-09-2003 09:55:32
Just bought a 3010 it had set up over a year,I changed plugs and drained gas,replaced with fresh gas and it fired up,I drove it home @ 9 miles and it ran good turned it off and couldnt crank it after some tinkering got it running again once again it ran good turned it off and couldnt crank it any help ? thanks Jeff
G-MAN
12-09-2003 13:40:43
 Re: JD 3010 carb problems in reply to Jeff Singletary, 12-09-2003 09:55:32
Is the engine not cranking, or cranking and not starting? What did you have to tinker with to get it going again?
Jeff Singletary
12-10-2003 13:13:20
 Re: Re: JD 3010 carb problems in reply to G-MAN, 12-09-2003 13:40:43
While tinkering I removed carb I didnt put it in a vat but I did a general cleaning.I tightened bolt on side of Distributer. Ive got fire at plugs but it doesnt seem to be getting gas.It seems that i have better luck getting it to run if I drain bowl on carb.
