Fly wheel clank
ken
03-28-2002 11:05:19
I have a 1938 Model B that i've gotten running recently, but it has a knock that seems to be comming from the fly wheel. I have 10 weight oil in the engine and have changed the gear oil. Is there a way to lubricate the flywheel? What else could be causing this Knock? Also, what size tires should be running on this tractor(thinking about replacing them with new rubber).
POPPER DICK
03-28-2002 18:51:39
 Re: fly wheel clank in reply to ken, 03-28-2002 11:05:19
Ken,
I have 12/4 x 38's on my 1950 "B" and I think it looks great with that size on it.
Dick
DAve K
03-28-2002 16:19:06
You have to get the flywheel on tight or it is going to knock. Even if the clamp bolts "seem" tight I get a big pipe on the end of the wrench and tighten some more. Not sure about the B but on my A the position of the flywheel also adjusts the end play of the crank. Have someone push in on the clutch pully as you tighten the center nut on the flywheel, clamp bolts loose. You want a little end play, not too much. Then tighten the clamp bolts down really tight. As others have said it could be wear on the crank or flywheel also but first make sure it is tight on the crank and not too much end play.
I would use a lot heavier weight oil in the engine also. I run 30 W in mine.
Dave
tractorboy
03-28-2002 15:12:55
Ken , Why have you got 10 wt. oil in the crankcase , just wandering cuz I live in the south and use 20w50 in all of mine .
Mike F
03-28-2002 12:20:29
There is a possibility that the flywheel is slightly loose or the splines are wore and letting it "bump" around. You could shim or buy a taper lock flywheel to fix if this is the trouble. I think it should have like 9x36 rubber, at least that is what mine had.
tim hinton
03-28-2002 19:13:09
 Re: Re: fly wheel clank in reply to Mike F, 03-28-2002 12:20:29
where do you get the shims or do you cut some strips of metal and put in the gaps and tighten? that kind of materal should be used? what is a taperlock flywheel? where would get one? $?. thanks
