4020 smoke
Duben
03-27-2002 20:09:46
Just bought a 4020 that, if you look close, puts out light smoke when idling. Don't really notice any when it's working. Is this normal or is there something wrong? Thanks in advance.
ray
03-28-2002 14:16:47
 Re: 4020 smoke in reply to Duben, 03-27-2002 20:09:46
Normal for some smoke. If it starts quick, Let everything be. Keep it full of oil and let it bump!
JD 4000
03-28-2002 11:51:21
yeah it smoke at start up. I have a 71 4000. it does the same. no oil burning. it's just cold when start up it smokes, when start up as it has been running before it wont smoke.
Dan s.
03-28-2002 10:07:48
I have a older 4020 with the big injectors and it always smokes at idle. just check the oil a few times after long usage and make sure its not burning oil. if its not burning oil i would leave it alone.
G Taylor
03-28-2002 12:40:50
 Re: Re: 4020 smoke in reply to Dan s., 03-28-2002 10:07:48
At idle rpm there is less heat & pressure to inject the fuel into. Plus there is less combustion chamber swirl & lower metal temperatures at no load/light loads. Combustion will not be as efficient. Fuel control at idle is difficult. Poor quality spray at the beginning & end of the injection event occupies a small % of time at full power but is a significant significant % at idle's short spray duration. For these reasons & others, some truckers are using small diesel generators on their highway tractors for power/heat/cooling while at rest stops.
G-MAN
03-28-2002 10:25:07
These guys are right, probably just some wear in the fuel system components allowing a little more fuel in at idle than it should have. If it starts smoking heavily at idle, have it looked at. Too much fuel in the cylinders at light loads will wash down the cylinder walls and score the pistons and liners due to lack of lube. I'd also check to see if the lockwire is still intact on the pump, somebody might have done a little shadetree tuning in the past.
guru
03-27-2002 22:30:03
Its pump and injectors or a little low on compression.If it starts good and you are otherwise happy with the tractor leave it alone.
It will fix itself when some day you may end up working on engine.I would check timing doesnt cost anything.
guru
03-27-2002 22:28:54
Bill A
03-27-2002 21:02:19
4020 diesel? Sounds normal to me. Nothing to worry about.
Josh
03-27-2002 20:37:48
to answer your question better I need to know if it a gas or a diesel. Dad's got a 64 model 4020 diesel with the old style pencil injectors in it and it's always put out a little blue smoke when it idles...people have told us thats normal for pencil injectors...beats me?.....we also have a 68 model 4020 diesel and it doesnt smoke and has many more hard hours on it....hgope this helps you in any way
