920 jd power steering dead
Larry Zavitz
03-27-2002 19:13:58
I recently overhauled brakes on this tractor since lining had been coming off disc and plugging the hydraulic filter.I have flushed it out and put in new oil and filter,main hydraulics seem fine but i have no power steering.it hasnr worked too good for past year,
any ideas what I can check to restore power steering.thks
G-MAN
03-28-2002 13:51:27
 Re: 920 jd power steering dead in reply to Larry Zavitz, 03-27-2002 19:13:58
I pulled up the 920 on EPC (not being familiar with this tractor) and found a power steering repair kit. It's part #AT26188 at your Deere dealer and lists for $53.59. It looks like parts for rebuilding the steering column (seals, gaskets, etc). I would probably start there. I've had the column on a 2240 apart before and this one looks kind of similar. As I recall (it's been a few years ago) it wasn't overly complicated. I would definitely purchase a manual or have pages copied from the dealer's manual, that should give you the info you need. Hope this helped, G-MAN.
