Hydrolic Lift on my 1941 H
Ron
03-27-2002 17:23:19
Hello:
I just finished rebuilding the hydrolic lift pump and cylinder on my 1941 H. Should the cylinder be able to stay "put" at any setting or only at full extension? Also will it hurt the cylinder or pump to lift it to full extension? The lift handle sort of "jumps" and snaps into the up position and stays there unless I force it to go back down. Is this normal? Thanks in advance.
Ron
normal
03-28-2002 18:27:36
 Re: Hydrolic Lift on my 1941 H in reply to Ron, 03-27-2002 17:23:19
That sounds about how I remember it from the little bit I ran a cylinder on mine.
Ron
03-29-2002 04:38:18
 Re: Re: Hydrolic Lift on my 1941 H in reply to normal, 03-28-2002 18:27:36
Thanks. It seems to only lock or "stay put" at full extension.
jdh
03-29-2002 17:09:28
 Re: Re: Re: Hydrolic Lift on my 1941 H in reply to Ron, 03-29-2002 04:38:18
I think the handles fly up hard as most tractors had busted cast piece that holds it.
Ron - Hey JDH???
03-30-2002 18:10:20
 Re: Re: Re: Re: Hydrolic Lift on my 1941 H in reply to jdh, 03-29-2002 17:09:28
That's exactly what happens. But is it designed to
"stay put" only in the full up position?
Any memories would be greatly appreciated.
Ron
jdh
03-31-2002 16:11:37
 Re: Re: Re: Re: Re: Hydrolic Lift on my 1941 H in reply to Ron - Hey JDH???, 03-30-2002 18:10:20
ron . I think the lifts are only full up or full down no in between.And they are designed to use the factory single acting cylinder which has to be installed the right way up as per arrow on casting their is a check valve of some sort or breather in the cylinder. I'm suprised no other people have commented in response. Guess most are busy typing insults about color wars!!! The lever
should stay up when cyl is extended. I have ran a couple of H's with hydralics but did not use them much.Just tractors I had and sold.
Ron - Thanks JDH
04-01-2002 15:38:36
 Re: Re: Re: Re: Re: Re: Hydrolic Lift on my 1941 H in reply to jdh, 03-31-2002 16:11:37
Thanks so much.
This confirms the action I witnessed and all seems to be working normally.
Best regards,
Ron
