420 5th Gear Noise?
Henry J
12-09-2003 08:01:10
I have finally worked my way to the rear of this thing on a final tear down on the restoration. The only reason I am taking the trans apart "again" is the 5th gear noise. This tractor started as a basket case. After I got it running we decided to move and I put it to work for a couple hundred hours. It has always had a trans noise in 5th gear. It sounds like gears not meshing together right, a bearing out that allows a shaft to be out of alignment or maybe a bearing totally out. It is so noisy that I hesitate to use the gear.
During the process of lanscaping I broke off a bunch of teeth from the ring and pinion. On that teardown, I looked the gears over and visually inspected the bearings and put everything back together to correct preload or free play. 5th Gear sounds exactly the same as before.
I have compared measurements on the shifting fork travel with a known good one. The fork rod slips/drops into the detent for 5th fine. The wear patter on my 5th drive and driven (slider gear compare the same as another one.
I have since gotten another 5th drive gear and slider and will put them in for grins when I go through it. Hopefully something will growl at me on this go around.
Any input out there concerning this hunt for a needle in a haystack would be appreciated.
Could it possibly be in a final drive?
Henry J (another clue)
12-09-2003 12:38:52
 Re: 420 5th Gear Noise? in reply to Henry J, 12-09-2003 08:01:10
I am running either 80 or 90-140 GL 5 in it.
The wheels are off, brakes removed, and top of transmission removed. I noticed that when the trans is in neutral and you take one hub and rotate it back or forth there is a very noticeable clackity clack which as best as I can determine is coming from the differential. When trying to observe from the rear the spider gears seem to be running smooth. I don't have any experience here but it seems that it should be a smooth roll with no light clacking noise?
Comments would be appreciated. Dang I keep remembering a saying I think was on the other board where a guy said "Stick a Fork in Me, I am done" lol.
silverado1
12-09-2003 17:40:45
 Re: Re: 420 5th Gear Noise? in reply to Henry J (another clue), 12-09-2003 12:38:52
Henry,
If its a clunking sound then it could quite possibly be a bearing that is bad. I had a couple bearings go bad in an red tractor and the only way i found that out is when I got done washing it in the parts washer and then spun it in my hand you could feel a distinct spot that wasn't round where that bearing was catching and getting held up. Im not sure if thats what your problem is but it sounds familiar, thats why I threw it out there. Good luck
Josh
P.s. Sometimes sticking a fork in it is the best thing.. lol
BMeyer
12-09-2003 14:27:20
Henry, I've gotten into the same thing you're experiencing. The clankity in the rearend is probably the adjustment between the output shaft and differential. You need to shim the output shaft to meet specs (listed in the service manual on page 130-20-9.) I don't have AM452T, the special tool they use, but I made one. That tool has a standard distance of 2.782 inches from the center of the gauge to the end of the tongue. That tool mounts up in the two large openings on the side of the casing where the differential bearing quills go.
Once the output shaft is shimmed, you'll need to shim the differential left to right to get rid of the 'backlash' between the output shaft and the ring gear.
I done a 430 little over a year ago and it took me all afternoon to get it done. Course, I had to figure out the math in making that tool. (Math was my second least favorite subject in school. Sure wish I had paid attention.) I'll have to dig in a couple boxes, but I'm sure I still have that tool if you'd like to borrow it. It's by no means as accurate as the special tool they call for, but it sure fixed the noise that was in the rearend. (I also had a very worn pinion shaft.)
As far as the noise with the gears....you can change gears and change gears, you'll almost always still have gear noise in those Dubuques. 140W oil is the best solution.
Let me know if you need something. I'll try and help.
BMeyer
silverado1
12-09-2003 11:06:59
what is the weight of the oil you are using in that transmission? My Napa man told me to use 80-90 but that was awful thin and made alot fo noise in my tractor. I drained that oil and put in 140wt and that quieted things up. Its just a thought, I dont know if that will work on your tractor or not. Good luck,
Josh
Wayne in Tn.
12-09-2003 11:16:36
 Re: Re: 420 5th Gear Noise? in reply to silverado1, 12-09-2003 11:06:59
Josh, that is about the best thing I have found, is to use the 140w. I once tried some stuff that was called 00-grease. It was so thick it made the noise worse. I don't think it could even get to the bearings, I flushed it all out and re-installed the 140w.
Wayne in Tn.
12-09-2003 08:58:35
Henry J. I would be very intrested, when you find the solution to the gear noise. I have just purchased a 40 that is loud in all gears, even reverse. Once, I had a 40w and I told myself that I was going to stop all gear noise. I put every bearing possible, in the trans. and final drives, set them all up with the shims, per the service manual. Spent over $700 for bearings, races and seals. GUESS WHAT? All the same gear noise was still there. I concluded it must be wear on the gears themselves, that you can't see with the naked eye. Or maybe wear on the shafts, that is not visible? I also remember as a kid, our Dubuques had gear noise, and they must have been only two to five years old at the time.
