JD single wheel what trcator does it fit
Strass
03-26-2002 22:21:04
Well I found a single wheel that attaches with four bolts and the tire size is 7.50-16. It is a big tire and it looks to be built pretty heavy. It looks to be factory John Deere but I do not know where to look to see if it has a part number even if it does have one. Does anybody out there know what it goes to. I can e-mail you images if that might help. Thanks for any help in advance
John
03-27-2002 07:49:28
 Re: JD single wheel what trcator does it fit in reply to Strass, 03-26-2002 22:21:04
Strass, Your single front wheel came from a later styled tractor. If the yoke is thin then it came from a BN with 42" rear wheels. If the yoke is really heavy duty then it came from a GN or AN. The AN would have had 42" rear wheels where as I believe that the G's were only shipped with 38" wheels. I do not believe that there are any G's with 42" wheels but I could be wrong. John
strass
03-27-2002 13:44:53
 Re: Re: JD single wheel what trcator does it fit in reply to John, 03-27-2002 07:49:28
Thanks for all your help all of you are great help. The #'s on the wheel is JD B2681R if that will help. Thanks again
Will P
03-27-2002 14:48:13
 Re: Re: Re: JD single wheel what trcator does it fit in reply to strass, 03-27-2002 13:44:53
It's for a late styled BN with 42" rear wheels only. BN's with 38" had A1235R and A1236R front wheels.
The number helps alot.
Will P
Ken Talatzko
03-27-2002 09:57:44
John,
The single front wheel was also available on tractors with 38" rubber and convertable pedestals, models A,B,G,and all numbered row crops tractors. Ken
Eric Egland
03-27-2002 06:17:59
It may be off of a late styled BN orAN. Does it have a yoke attached? The wheel itself is cast iron I believe.
JDJIM
03-27-2002 04:31:41
It fits any 10 and 20 series that had roll-o matic on it and I think the nunber series 2cly tractors . They were made by Deere , there was also a smaller diameter wider tire for it too .
They are shown in the parts book .
