ClooneyWill P re. knocking model B
tim hinton
03-26-2002 20:08:28
thanks for info i will check the flywheel. it (the knock) does get quieter if you push foward on the clutch handle real hard (Sometimes) about the same knock under load seams louder at low rpm about the same hot or cold.thanks again i will see if i can move the flywheel to corect the end play.
Ron
03-27-2002 13:40:39
 Re: ClooneyWill P re. knocking model B in reply to tim hinton, 03-26-2002 20:08:28
If it is end play....loosen the flywheel enough for the BIG nut to tighten ( move ) the flywheel in, to get rid of the end-play.....I take all of it out, but not enough for it to cause any binding, then tighten the flywheel bolts....TIGHT.
..about 200 lbs on the end of the JD wrench... Then set the nut with a punch, or screw driver and hammer...
