JD 60 Clutch
John W
03-26-2002 14:03:09
Well I removed the clutch disc and the drive disc and also the belt pulley. everything looks pretty good. the adjusting bolts are rusted in place. Are they suppose to move or slide in and out? The clutch facings did'nt look bad. The clutch would'nt snap in or out when engaged or disengaged. I bought a new fixed disc and two floating discs and three springs so far. I could use any help or advice thanks john
Clooney
03-26-2002 14:17:11
 Re: JD 60 Clutch in reply to John W , 03-26-2002 14:03:09
John, the adjusting bolts must slide easily in the holes through the pulley & the bolts shouldn't have any step wear where they go through the holes. A little high temp grease should be put on the bolts & "T" heads during installation so they slide easily.....
