G ring gear question
Jack
03-26-2002 06:36:48
I have a 53 G and my question is,can the ring gear be turned around or not?I have heard several theories on this.Thanks
oldtimer
03-26-2002 17:11:00
 Re: G ring gear question in reply to Jack, 03-26-2002 06:36:48
why do you turn the ring gear around?? just asking, maybe I'll turn mine around.
JAck
03-27-2002 08:03:29
 Re: Re: G ring gear question in reply to oldtimer , 03-26-2002 17:11:00
Because it has worn teeth on the spot where the engine stops.When I get ready to start it it will slip on this spot.
BobTGS
03-26-2002 07:20:32
Yes Jack, it sure can.I just did one in the shop last week.Be sure to grind a bevel in the teeth so the starter pinion can engage.Bob,from Triple G Service.
Jack
03-26-2002 08:00:49
 Re: Re: G ring gear question in reply to BobTGS, 03-26-2002 07:20:32
Thanks Bob.If.125 over aluminum M&W high comp pistons will give a G with 100 psi compression 55 hp,what will 110 psi make one?Thanks again Bob.
BobTGS
03-26-2002 12:24:14
 Re: Re: Re: G ring gear question in reply to Jack, 03-26-2002 08:00:49
Well Jack ,I don't know .But if was to guess, there probably would'nt be a noticable differance.Bob,from Triple G Service.
