2 cylinder diesel question
Scott in SC
12-09-2003 05:57:59
How long should the pony motor run on a JD R before I start the main engine? Doesn't the pony preheat the main engine?
Bo in Maryland
12-09-2003 06:57:28
 Re: 2 cylinder diesel question in reply to Scott in SC, 12-09-2003 05:57:59
..... one thing that the book mentions is:
"allow the cranking engine to turn (or "motor") the Diesel engine until oil pressure registers on the oil gauge. THIS IS IMPORTANT. In cold weather it is necessary to motor the Diesel engine for a longer period of time"
para.4 p.23 Operator's Manual OM-R20699
Good luck to all!
Bo
Workin' 730
12-09-2003 06:25:40
Scott; We have and still use our restored 730 D with pony back home in PA for various tasking. I usually start the pony and let it warm up at a little above idle, for about two minutes, then I turn up the throttle and pull the decompression lever and cluth in the pony and turn over the engine(no throttle) until it comes up to speed and then release the decomp lever and ease the throttle to her until she fires, then I idle the pony down and secure it. So overall a cold start takes around 5 minutes. Hope this helps.
R/
Eric
Scott in SC
12-09-2003 06:29:12
 Re: Re: 2 cylinder diesel question in reply to Workin' 730, 12-09-2003 06:25:40
Thanks, you just answered my second question, too.
Bo in Maryland
12-09-2003 06:18:42
.....Scott, I don't know the recommended warm-up time on a JD R, but on my 730 the book calls for 1 to 3 minutes depending on the temperature..... right now it's 26 degrees outside so on a morning like this I will give it the full 3 minutes.....my pony is very faithful, even on the coldest days and even when my neighbors can't get their Fords started.....
P.S.I also back my tractor into the shed in the winter.....I want the front to catch the warming effect of the sun.....I feel like it gives me a little extra edge.
Good luck to all!
Bo
Scott in SC
12-09-2003 06:27:19
 Re: Re: 2 cylinder diesel question in reply to Bo in Maryland, 12-09-2003 06:18:42
Should I let the pony warm up at a slow idle, or should I speed it up?
Gpower
12-09-2003 07:22:38
 Re: Re: Re: 2 cylinder diesel question in reply to Scott in SC, 12-09-2003 06:27:19
Some of the R ponys did not have a slow idle, it was just wide open from the start...so I have read and seen literature on it. My R is idle adjustable, the more you pull the rod out the faster it runs, some did not have that, and there is no rod. Anyhow, what I was told?? Later
Scott in SC
12-09-2003 07:56:07
 Re: Re: Re: Re: 2 cylinder diesel question in reply to Gpower, 12-09-2003 07:22:38
Mine has the adjustable idle. Seems like it would be bad on the pony to start it and run it wide open while its cold.
Harry
12-09-2003 08:15:23
 Re: Re: Re: Re: Re: 2 cylinder diesel question in reply to Scott in SC, 12-09-2003 07:56:07
I don't have the adjustable control on mine and yes it is a little scary starting it up at full throttle. I feel a little better about it since everything in the motor is new. With the adjustable type does that mean that you can adjust it from the drivers platform?
Scott in SC
12-09-2003 08:51:06
 Re: Re: Re: Re: Re: Re: 2 cylinder diesel question in reply to Harry, 12-09-2003 08:15:23
Yes, its adjustable from the driver's seat.There are four controls. Throttle, choke, electric start (pull type rod), and manual pony start(rope pull type not unlike on a briggs lawnmower engine)
