JD 60 Powertrol...
Tim
03-26-2002 05:55:45
My 60 has a problem holding its 3rd pt or any implements (Haybind) in the raised position. The hydraulic pump will raise the equipment. But the haybind or 3rd pt will bleed off in almost 3 seconds. You have to keep the control arm in the raised position to keep it up. I tried to fix this once by putting in a Large O-ring and Paper gasket on the piston of the powertrol. It slowed it down a little but still does the same thing. Any Ideas would help, thanks.
