70LP Crankshaft and rod brgs
donwisc
03-26-2002 01:46:32
My buddy and I were at the JD store today to get replacement rod brgs. All thats avail are std and .022 under. They did not have a 70 manual so we could not get the original crankshaft brg dia. WE would appreciate it someone out there could provide this dimension.
This is going to get messy in that we have a .013 difference between the 2 brgs so someone may have ground only one brg dia in the past. Also there were no identifying numbers on the old brg shells
SEAMO
03-26-2002 09:30:03
 Re: 70LP Crankshaft and rod brgs in reply to donwisc, 03-26-2002 01:46:32
My records and manual say's STD rod journal is same on gas and LP 3.3745---3.3755 SAme as "G" with insert type rod's Bearing's should be available from Federal Mougal or Clevite The federal part number is 2155SB STD. OO2 010 020 030 sizes. Go to your bigger shop's that does crankshaft grinding they should be able to help you.If not give me a call 217-586 3604 SEAMO
donwisc
03-26-2002 09:45:08
 Re: Re: 70LP Crankshaft and rod brgs in reply to SEAMO, 03-26-2002 09:30:03
Thanks a bunch SEAMO, Coincidently I was talking to a bearing house this morning about a crankshaft seal that is not carried by JD anymore but is available thru them from Federal Mogul. They will probably have these shells too.
United we should be able to fix anything
Don
