Cost of a wheel rim? 38in. or 42in.
tim hinton
03-25-2002 19:25:59
the 48 jd mod. b i looked at today has one 38in.rim & one 42in. rim what size would be cheaper in to buy? the tractor is a BN but i think they came with 38s or 42s size tires.
tim hinton
03-25-2002 20:43:06
 Re: cost of a wheel rim? 38in. or 42in. in reply to tim hinton, 03-25-2002 19:25:59
thanks wife of a JD collector i also need the wheel any idea of the cost?
CLARENCE
03-25-2002 22:53:45
 Re: Re: cost of a wheel rim? 38in. or 42in. in reply to tim hinton, 03-25-2002 20:43:06
TOM:
I HAVE A 42 INCH RIM SPARE THAT CAME WITH MY 48 BWH STYLED TRACTOR IT NEEDS A SMALL SECTION TO BE CUT OUT AND REPLACED AROUND BY THE VALVE STEM IT CAN BE DONE WITH NO GREAT DIFFICULTY OPEN TO ALL OFFERS
Wife of a JD Collector
03-25-2002 20:32:08
Good luck in finding 42" rims. They are hard to find and very expensive. You can find 38" rims in just about any salvage yard for maybe 100-150 dollars a piece (with a 9 bolt center) and you can still get them brand new for a little more.
JD70Jim
03-25-2002 20:25:51
According to several books I have, including PC 675 (which is for an A btw), I observe that a big distinction for the BN, BW, AN, and AW tractors is that they all came standard with 42" rubber! You could also get the regular A and B with the two piece pedestal and a wide front end or a single wheel front end, but those tractors were regular As and Bs, not AN,BN or AW,BW tractors. As regular A and B tractors, THEY had 38" rubber! If what you have is a real BN, it should ONLY have the 42" rims (provided you want autheniticy and care, that is)
tim hinton
03-25-2002 20:40:45
 Re: Re: cost of a wheel rim? 38in. or 42in. in reply to JD70Jim, 03-25-2002 20:25:51
thanks jd70jim that is what i thought that the AN and the BN had 42 in. wheels but i was told they could be ordered with 42 or 38 in wheels?
RK
03-26-2002 05:10:41
 Re: Re: Re: cost of a wheel rim? 38in. or 42in. in reply to tim hinton, 03-25-2002 20:40:45
I believe they could be ordered with 38 inch wheels as we have had some set up both ways. the real difference is in the rearaxle housing where the drawbar attaches, if you've seen them both together you could see it. also the axles were usally longer on both W's and N's. The 42 inch casting and wheels will be an attention getter at a show though. RK
