730 Diesel flywheel bolts??
Mike
03-25-2002 13:44:30
I need to replace the flywheel bolts on my 730D, should I use grade5 fine thread, or saomething else??
Frank-in-Tallahassee
03-25-2002 14:56:29
 Re: 730 Diesel flywheel bolts?? in reply to Mike, 03-25-2002 13:44:30
Mike:
I asked around, and quite a few folks suggested upgrading to hardened, fine thread over the standard JD bolts. Even if you use the JD bolts, you should replace them at service intervals as they can stretch quite a bit.
I got a new set of bolts for my 70D, and they are Grade 8, fine thread, tall nuts with hardened washers.
You can can get them from Albert @ Renaissance Tractor (800-784-0026) if you don't want to scout them up yourself.
70D // 855
ChuckW
03-25-2002 14:07:38
why not use the JD replacement?
