My 3010D has a fused line between the two 12 volt batteries and the frame. When one set of lights (and usually the fuel guage and oil pressure light) doesn't work, I usually have to replace the fuse. I have not figure out how or why, but the fuse doesn't blow. Some how some sort of corrosion builds up on the fuse. I've used an ohm meter to test the fuse and it worked fine, but when the fuse was in the holder, it checked out bad. Put in a new fuse and things work...go figure. I also have a 4020D that had 24 volt setup. That setup used the tractor frame as part of the wiring. Both batteries were tied to the frame directly. I finally converted the 4020 from 24 to 12 when my starter fried. Was 190USD to fix starter, 415USD to convert to 12 volt. Best fix decision I have ever made. Personally, if you can afford it and you don't have things "in the way", I'd spend the money and go to 12 volt setup. I haven't done it on my 3010, as my fuel filter is in the way. The suggested workaround for that is to move the filter out away from the tractor. Also need to do something about my water line coming out of the block. The corner fitting is too large to allow the longer starter to fit. I spend about 3 times a year messing with my 3010 with electrical problems. Did the same with my 4020 until I converted to 12. Haven't touched the electrical on my 4020 since. As was suggested learning and understanding each component of the electrical system is a must. Otherwise you will spend a lot of time in frustration learning the "hard way".
