Which way does threaded stud go in?
Bill Oakes
03-23-2002 15:24:03
I have a '48 B with heavy cast center discs. Threaded studs screw into the cast disc, then a big nut holds the clamp that squeezes the rim. New studs have a taper thread on one end with straight threads on the other. Logic tells me the taper should screw into the cast disc so the big nut can go on the straight thread. I can't get the tapered thread to screw very far into the casting but the straight thread will. If I do that it seems that the nut will not go all the way on to tighten the clamp. Which way is it supposed to go? Or do I possibly have the wrong studs? Thanks for helping.
Larry W.
03-24-2002 06:16:33
 Re: Which way does threaded stud go in? in reply to Bill Oakes, 03-23-2002 15:24:03
Bill, I don't know if I have the same studs on my B as you, but the end with the nut is certainly not "tapered". It may be that is by design so they don't come out of the casting as aligning the heavy cast wheel to the hub would be a job mounted on the tractor. Have you tried running a thread tap in the holes? Could these be like pipe threads? Sorry I am not a lot of help.
