2940
Charles
03-22-2002 19:12:43
The PTO won't disengage the control level feels the same any ideas on where or what to start on never had this problem before Thanks
Gord
03-23-2002 08:58:32
 Re: 2940 in reply to Charles, 03-22-2002 19:12:43
Remove the top cover assembly that the pto lever is mounted in. Inside the cover you will find that the small snap ring on the end of the PTO valve has fallen off and the valve will not return to the shut off position. A new snap ring will need to be installed. Also make sure that the PTO valve moves freely in its bore.
