2010 Tachometer
Gary Edwards
12-08-2003 16:14:46
I ordered a tachometer for my 2010 serial number 14355 from my John Deere dealer, but when I installed it, it didn't work. It appears that the tachometer is built for a tachometer drive that rotates in the opposite direction. When I spin the input of the tach in the direction that the tach drive rotates, there is no needle deflection, when I spin it in the opposite direction, the needle moves in the right direction. The part number of the tachometer I received is AR65445, which my parts manual shows as appropriate for serial number 29001 and higher. My dealer tells me that they were all superceded to this number, and no others are avaialble. I didn't find this too helpful. Appears to me that the correct part number is AT17746, which is marked as NLA. Has anyone else had this problem? Is there a solution? Can the original tachometer be repaired?
firedog
12-09-2003 16:09:24
 Re: 2010 Tachometer in reply to Gary Edwards, 12-08-2003 16:14:46
Gary,
I ran into the exact situation about two years ago.
In fact, we tried two similar but different tach's from JD but they wouldn't work because of the rotation.
I sent my tach to Gary Schmidt in Iowa and he had it rebuilt for me. It was a quality job.
Try 641 822 4662 or e-mail [email protected]
Gary Edwards
12-09-2003 17:17:06
 Re: Re: 2010 Tachometer in reply to firedog, 12-09-2003 16:09:24
Thanks, I'll give him a try.
