420 S Differential Bearing quill ?
Mark Miller
03-22-2002 13:09:42
I had to remove differential bearing quill to replace a seal. I didn't measure the gap between quill and differential before disassembly. Is there an easier way to reassemble the quill to differential and get the .005 bearing preload without removing the pinion and following all the steps in the manual to establish the correct shim thickness. I would think that this has already been determined. All I want to do is torque the 6 bolts holding the quill back to some value.
Thanks in advance,
Wayne in Tn.
03-22-2002 17:23:25
 Re: 420 S Differential Bearing quill ? in reply to Mark Miller, 03-22-2002 13:09:42
Mark, if you did not have the carrier bearings off, the adjustment should be ok. the shims go behind the bearing.
