Clooney i need help lever on john deere 40..
harold e. gray
03-22-2002 10:48:47
i have a john deere 40 and there is a lever under the seat on the left side , it is about 4 inch long with a cam at the end of it,when you move the lever the cam pushes the pin in . can you tell me what this lever is for.i have always had ford tractors before so john deere is new to me.i dont want to use the lever untill i find out what it is for..... please help. thanks harold
Wayne in Tn.
03-22-2002 17:14:09
 Re: clooney i need help lever on john deere 40.. in reply to harold e. gray, 03-22-2002 10:48:47
Harold, the lever is for 2 different settings to use the dual powertrol. With the lever forward and the left lift arms pinned together is for max lift using both pistons.---With the lever to the rear and the lift arms on the left side un-pinned you have independent use of either side and the left control knob will control the left side and the right control knob will control the right side. Caution;;; if using in the forward position, DO NOT use the left control lever-knob to operate lift or damage can result. Keep the left lever behind a stop to keep from using it. This is a feature of the Dual Powertrol to use front mounted cultivators or other equipment and enables you to lift either side independently.
Wayne
03-22-2002 17:16:44
 Re: Re: clooney i need help lever on john deere 40.. in reply to Wayne in Tn., 03-22-2002 17:14:09
Sorry, I just noticed you posted to Clooney. Maybe he can help more.
Clooney
03-23-2002 05:17:59
 Re: Re: Re: clooney i need help lever on john deere 40.. in reply to Wayne, 03-22-2002 17:16:44
Wayne explained the operation as good or better than I could have..... .
