4010 most copied?
Lucky Len
03-20-2002 18:48:24
Why does JD and JD fans proclaim the 4010 tractor and the 55 combine as the most copied in the world? I can't see it.
JIM
03-22-2002 15:47:42
 Re: 4010 most copied? in reply to Lucky Len, 03-20-2002 18:48:24
THE 4010 IS A COPY OF THE OLIVER 1800.JUST LIGHTER AND LESS POWER.AND THATS A FACT.
www.getalife.com
03-23-2002 21:29:14
 Re: Re: 4010 most copied? in reply to JIM, 03-22-2002 15:47:42
Now I've heard it all... 4010 a copy of an 1800, lets see, they started developing the new generation in the late 50's.
I think brain dead is a generous term!
Keep smiling!
Steven M
03-22-2002 18:19:38
Your 1800 don't have
Roll-Gard
Power differential lock
Closed center Hydraulics
Hydraulic Power Brakes
Posture seat
Lucas
03-22-2002 18:46:04
 Re: Re: Re: 4010 most copied? in reply to Steven M, 03-22-2002 18:19:38
A 4010 didn't have Roll-Gard or differential lock either. What about dry air cleaner and turbocharging or tilt steering or side console controls or a large operator platform or spin out wheels or ground fill fuel tank or a wet clutch or etc,etc.... Oh wait JD did have first roll-o-matic and front mount fuel tank and rack-and-pinion rear axles.....dang...nobody copied those.
A name for a seat means nothing either!
Steven M
03-20-2002 19:15:21
The 4010 tractor and the 55 combine,are hailed as being ahead of it's time.
Yesterday, Today & Tomorrow!
Nothing Runs Like A Deere!
DAVE M
03-21-2002 09:28:08
 Re: Re: 4010 most copied? in reply to Steven M, 03-20-2002 19:15:21
I AGREE THAT THE 55 COMBINE WAS WIDELY COPIED.
BUT THE 4010 HAD PROBLEMS THAT'S WHY DEERE BROUGHT
OUT THE 3020/4020 IN 1963 TO CORRECT THE 3010/4010
PROBLEMS.
Leaner, Meaner, Cleaner ,GLEANER!
03-22-2002 19:38:36
 Re: Re: Re: 4010 most copied? in reply to DAVE M, 03-21-2002 09:28:08
Don't try to put a lowly 55 with the ranks of a Gleaner let alone above a Gleaner. LL
They don't even paint Gleaner
03-23-2002 04:54:41
 Re: Re: Re: Re: 4010 most copied? in reply to Leaner, Meaner, Cleaner ,GLEANER!, 03-22-2002 19:38:36
Lucky Len
03-21-2002 14:34:18
Give a few exsamples as to why the 55 would be considered most copied and a few reasons why the 4010 or 4020 would be. I know of a couple "first" for each but every company has a couple.What features excactly would be the reason to identify these machines as "The most copied". Thanks.
TBear
03-22-2002 07:38:51
 Re: Re: Re: Re: 4010 most copied? in reply to Lucky Len, 03-21-2002 14:34:18
We can thank deere for giving us a tractor with multiple cylinder vertical inline engines,even though everybody else was doing it for 30 or 40 years or more.
Steven M
03-21-2002 15:35:02
The 55 combine had retracting fingers in the platform auger. If you look at any combine made today,it has retracting fingers.
As for tractors. I think the most copied of all things,is the name Power Shift!
Ford had Select-O-Speed. You don't see that name used today. Today! CaseIH Ford MF and you name it has Power Shift.
Not Excactly
03-21-2002 16:27:21
 Re: Re: Re: Re: Re: 4010 most copied? in reply to Steven M, 03-21-2002 15:35:02
Having fingers or an auger platform at all is a Gleaner thing, about 1930. The Power Shift name thing is pretty weak cause what about Hart Parr and the use of the name "tractor". LL.
Steven M
03-21-2002 18:27:52
 Re: Re: Re: Re: Re: Re: 4010 most copied? in reply to Not Excactly, 03-21-2002 16:27:21
Well! lets see!
Roll-Gard
Posture seat
Closed Center Hydraulics
Hydraulic Power Differential lock
3 point hitch (with lower link sensing)
Syncro Range Transmission (with synchronizers)
55 Combine
Was the first combine in the industry to center the operator on top and locate the grain tank and engine directly behind the operator.
John Deere green paint!! Gleaner NO PAINT!
Darren
03-21-2002 20:25:59
 Re: Re: Re: Re: Re: Re: Re: 4010 most copied? in reply to Steven M, 03-21-2002 18:27:52
I thought MF or Fordson had the first 3 pt hitch??
Steven M
03-22-2002 04:42:11
 Re: Re: Re: Re: Re: Re: Re: Re: 4010 most copied? in reply to Darren, 03-21-2002 20:25:59
Yes MF and Ford did have the first 3 pt hitch. But it did not have lower link sensing.
newgen
03-21-2002 20:59:52
Planetary final drives----4010/4020---Often imitated---never duplicated--
