Spindle Nut on Roll a matic
Ben.So.Tex
03-20-2002 16:16:39
The treads are worn and stripp on the spindle of my 730 How can I repair this with out buying a new spindle.Thanks Ben
Plant Doctor
03-21-2002 06:04:38
 Re: Spindle Nut on Roll a matic in reply to Ben.So.Tex, 03-20-2002 16:16:39
Ben: You can purchase a split nut from a truck parts supply house or a good auto parts supply house. The nut has a 3/32" - 1/8" split in one side and is drilled and taped to accept a socket head screw that when tightened will pull the split together decreasing the inside diameter of the nut. Use a die and chase the spindle threads and then screw on the split nut and tighten until the bearings are adjusted properly. Then tighten the socket head screw on the split nut as tight as possible which will hold the nut in place on the spindle. This works very well if the spindle threads are not completely gone.
Tractorboy
03-20-2002 18:08:20
Well, you can get an adjustable die nut and cut the threads down till they have a good form and then have a nut machined to fit it otherwise it has to come off and then build up and turn and rethread .
