John Deere 2030
Nicholaus Sowde
03-20-2002 06:47:37
Is $8,000 to much or what? It does not say whether it is gas or diesel. It just says John Deere 2030 $8,000. Thanks
John Henry
03-20-2002 09:45:00
 Re: John Deere 2030 in reply to Nicholaus Sowder, 03-20-2002 06:47:37
8000$ seems the going rate in good shape. I dont believe Deere made the 2030 with a gas engine.
Steven M
03-20-2002 16:42:04
 Re: Re: John Deere 2030 in reply to John Henry, 03-20-2002 09:45:00
Yes they made a 2030 Gas. Don't feel bad! I didn't know that,but the other day i had to go to my John Deere dealer,and i was looking around and they have a 2030 Gas.on the lot. I didn't ask the price.
G Taylor
03-20-2002 10:28:48
Built for the 1972 through 1975 production year, about 71HP. Is this an American 2030 an 2130 imported from Canada repainted. No problem as they were a fine tractors as long as no-one put SAE 140 in the transmision instead of Hy-Guard.Pull the trans oil filter & look for brake material. There was also an overseas 2030 which shows up due to the strong US dollar.
JD70Jim
03-20-2002 11:00:45
 Re: Re: Re: John Deere 2030 in reply to G Taylor , 03-20-2002 10:28:48
I think you will find that the 2030 was 60 hp. It was the 2630 which was 71hp. The early 2440 is the same tractor, except for the hood.
Why SAE 140 in the tranny? It is the same reservoir used for the remote hydraulics. I use the LOW VISCOUSITY version of Hygard in the 2440.
The price, $8000, seems to be the going rate, w/o loader.
G Taylor
03-20-2002 12:07:05
 Re: Re: Re: Re: John Deere 2030 in reply to JD70Jim, 03-20-2002 11:00:45
I don't know why some people put gear GL5 etc lube in the transmission instead of hyrdraulic/gear oil such as Hy-Guard either? They havn't read the manual or don't realize the hydraulics/brakes/power steering are a common oil system I guess. Sure ruins the brake friction pad material in a hurry however. My uncles/Grandfather wrecked a 2120 that way. The 71 Hp rating is listed in Vol II of John Deere Tractors & Equipment by Macmillan & Harrington on page 386 for the Mannheim gross flywheel rating. The US rating is likely a net value with 60HP.
