G starter
oldtimer
03-19-2002 20:18:56
restoring a 46 gm there is no starter with it, is there any other starter that will interchange with it? I have it runable but i'm switching the starter back and forth with my 48"G" any help out there??
kelly
03-20-2002 15:42:42
 Re: G starter in reply to oldtimer, 03-19-2002 20:18:56
try you a starter off of a 460 farmall. i run one of those till i could find a g starter.
JDGnut
03-19-2002 20:34:26
JD still uses the 3 bolt pattern used on the G's.. I use a gear reduction starter off a 7.6L or a 8.1L JD... most of the other starter will fit in the hole, but the cut out in the crank case over is not big enough for some of the longer starters.. Sorry I do not have a part number..
JDGnut
oldtimer
03-19-2002 20:45:52
 Re: Re: G starter in reply to JDGnut, 03-19-2002 20:34:26
not up on the "newer"JD's what's a 7.6 or8.1???Thank's for the info might be cheaper ?? to go that route.
G-MAN
03-19-2002 21:17:22
 Re: Re: Re: G starter in reply to oldtimer, 03-19-2002 20:45:52
Deere uses a lighter weight gear reduction starter on the newer tractor engines - 8000 series etc. This will probably not be cheap, new ones list for about $700 I think. You can use a starter off of a 4430, 4450, 4560, etc etc etc. Just check the length. A friend of mine that pulls a bigger G uses a 4430 starter on his.
oldtimer
03-20-2002 06:34:17
 Re: Re: Re: Re: G starter in reply to G-MAN, 03-19-2002 21:17:22
thanks guys I'll make a run on the local salvage yards,should be able to find something, now that I know what to look for ,even a rebuilder would be a great help. It's a long way from a show bird so I do have time Thanks again.JCM
