Dumb Question
rooster in tenn
03-19-2002 17:49:34
This is a dumb question, but can someone please explain how you get a burnt valve? I have worked on a lot of tractors and have seen burnt valves, but I really don't know how it happens. Anybody's opinion would be helpful.
Rooster
Bryan
03-20-2002 07:06:30
 Re: Dumb Question in reply to rooster in tennessee, 03-19-2002 17:49:34
Running too lean with a hard load for an extended period of time can burn a valve.
Ron
03-20-2002 04:56:58
I like to have valve spring tension a little on the "High" side, to be sure the valves don't "bounce", and to close them with a little more pressure.... A valve that leaks is subjected to a jet of fire that is like a Torch..!!! A seat of proper width , properly positioned, with good stems will give a "Perfect seal"... Then the valve COOLS against the seat, likt it is supposed to...Good valve rotators help, too...
G Taylor
03-19-2002 18:15:33
Too tight valve lash, extended max HP operation & detonation on spark ignition engines. The single largest cause is something that causes the valve/seat to be out of alignment. Bent valve stems, crooked valve jobs & the worst offender, worn valve guides. Common to have "Billy Bob Budget" come in with a head to be "rebuilt" and only the valves & seats are to be ground but no new guides/valves. He's back soon and mad with more burned valves as the wobbling ruined them again.
Bill from up north
03-19-2002 20:15:05
 Re: Re: Dumb Question in reply to G Taylor , 03-19-2002 18:15:33
I agree with the others to a point - Sometimes it because the valve lash was too great, the valves and seats pounded out to wide and then a piece of carbon held up the valve and it burnt. If the seating surface of the seat is left too wide when grinding them ,then the impact of the valve on a loose piece of carbon is not great enough to break it up so it gets blown out the port. Also pulling an engine harder than it was designed for -ie: putting a pickup engine in a medium duty truck. the pickup engine won't have sodium valves and stellite seats and can't stand the heat generated-so the valves warp and then burn out the valves and often the seats too. I often have to do a two angle grind on even stellite seats to get the seat narrowed-up properly. Worn guides is not a good thing either. I changed 11 out of 24 on a set of heads the other day.
another doug
03-19-2002 18:14:28
burnt valves as i understand are caused when a valve does not close all the way, it cools(ever so slightly) when it contacts the valve seat(heat disipation) these parts run a dull cherry red at times when under load ,so when valve lash adjustment goes south ,and it doesn't allow valve to close and make contact for the short time that is allowed, then the heat stays in the metal and it burns,and the sealing capability of the valve is compromised, also a valve will warp if you shut off an engine that is HOT, so if you are plowing or mowing and too proud to drop it down a gear and lug your engine down and kill it, well you might get to see your engine apart very soon
Steven M
03-19-2002 18:14:19
I think that comes for carbon,getting between the valve and valve seat.The carbon gets so hot in that one place that the steel(valve) melts.
Tye
03-19-2002 18:00:08
I am not sure but maybe back fires can cause burnt valves.
