JD60 Duplex carb
Leon R
03-19-2002 12:26:27
I am going to be cleaning and overhauling the carb on my 60. I have a carb kit coming but the JD service manual I have says to refer to"carburetors and fuel systems" section in "tractors and engines (general) Unit of the service Manual for carburetors overhaul procedure. It must be another manual because mine doesn't have such section. Does anybody have the parts breakdown on the carb. Iam particularly interested in how the small steel balls are removed and replaced for cleaning.
thanks.
John Hicks
03-19-2002 19:04:18
 Re: JD60 Duplex carb in reply to Leon R, 03-19-2002 12:26:27
Hi Leon, I just finished rebuilding the carb on my 60. It was dirty with fine rust from the gas tank. The tank is another story. This was the first time I rebuilt a JD carb and it was not that hard. Just make sure after disassembling, to soak it in a good carb cleaner. You probably won't have to remove the little balls. They are a pain as I understand it. Make sure everything is clean and the small holes in the venturies are open. Use spray carb cleaner and spray over these small holes to form a puddle of cleaner and if they are open you can see bubbles as the cleaner drains down through. Good luck
Randy
03-19-2002 13:12:56
I have all the manual at home and will scan and e-mail you the pages that you will need to do the job. I just payed someone to do mine, less work
and headaches
Leon R
03-19-2002 17:55:09
 Re: Re: JD60 Duplex carb in reply to Randy, 03-19-2002 13:12:56
Thanks Randy, looking forward to receiving that.
