JD 50 Front Plate
Tye
03-18-2002 17:54:29
I see a lot of pictures of John Deeres of different models having different items in the front of the tractor where the two bolt holes are. I've seen plates and hooks of different sizes. Does anyone recommend anything they've made or seen that I could make to put on my 50? Id appreciate any help.
gunthree,jed,billybob
03-19-2002 09:11:35
 Re: JD 50 Front Plate in reply to Tye, 03-18-2002 17:54:29
yeah, you could put a deer on the front, that looks real nice if y'alls wanted my opinion
Walt F
03-18-2002 18:27:04
The front plate you refer to was there to assist in mounting and holding in place, the front mount cultivator. the plate looked like a step that was bent down slightly and a bar (part of the cultivator frame) lay across it. Is that the plate you are talking about?
Frank-in-Tallahassee
03-18-2002 18:30:25
 Re: Re: JD 50 Front Plate in reply to Walt F, 03-18-2002 18:27:04
Walt:
You're right !
And most every on you saw had a hole torched in it to back wagons with !
70D // 855
Kerry Miller
03-19-2002 11:22:21
 Re: Re: Re: JD 50 Front Plate in reply to Frank-in-Tallahassee, 03-18-2002 18:30:25
Yep, mine has that plate, it also has the little cone-shaped thing. Unfortunately, I don't have any cultivators for it, but I saw some at a used tractor dealer on a 50, and it even has fenders!
If you guys like, I'll take a pix of that plate on mine so you can see what it looks like, but it sounds like you already found one.
Kerry
Walt F
03-18-2002 20:55:41
Go to e-bay then go to item # 1083918604
03-19-2002 06:53:23
 Re: Re: Re: Re: JD 50 Front Plate in reply to Walt F, 03-18-2002 20:55:41
Yep...complete with hole !
Frank-i-T
