John Deere B oil pump?
greg christoff
03-18-2002 07:20:14
I have a 1950 John Deere B, and after an oil change the oil pressure went from M-H on the gage to near L. I put a new oil filter and 30 weight oil in it, but it just doesn't seem to have the pressure. I have a JD book, that talks about the oil pump, but I do not understand where the oil pump is. Do they have replaceable oil pumps? If so, how do you replace them....greg
Jerry (KS)
03-18-2002 18:04:04
 Re: John Deere B oil pump? in reply to greg christoff, 03-18-2002 07:20:14
I also had this same problem on my 1940 model B after I o/hed the engine. It was my fault. I tightened the stud (A518R) too much and it lifted the oil pressure leaf spring. (in the oil pressure adjustment part) Try taking the oil filter off and back the stud off a 1/2 to 3/4 turn. I'll bet you get your oil pressure back.
Clooney
03-18-2002 09:45:00
Greg, the oil pump is in the bottom of the crankcase & driven by a rod & bevel gears from the camshaft. The bolts that hold it in are on the bottom of the crankcase. The oil pumps seldom if ever just go bad on a 2-cylinder Deere & if you have any oil pressure at all the pump in turning.
~If you had oil pressure before the oil change & don't have after, you have either dumped the new oil in the wrong fill hole, picked up dirt in the regulator valve, or overtightened the oil filter cover. Seeing as you have some oil pressure I'm betting that you overtightened the oil filter cover & distorted the oil filter can where it attaches to the filter head inside the crankcase. ~Pull the oil filter cover back off & see if the stud is crooked, leaning to one side or not centered, if so you have more than likely distorted the filter can at the top & the crankcase will have to be opened up, the filter head & lines removed then the can pressed out from below with a pipe & jack. Once out it can be replaced, or if not bent too bad straightened & re-installed. Once the top of the can is bent the gasket will blow out causing a severe oil pressure drop.
~If the filter cover stud is straight & centered then you might have just picked up some dirt when the oil pump re-primed & it is stuck in the oil pressure regulator valve. If that is suspected, adjust the regulator valve open a turn or two & see if the higher flow of oil through the orifice will blow the dirt out (once in a while you can get lucky). If not you will have to pull the filter head & clean the regulator orifice (hole).
~There could be other reasons you now don�t have oil pressure but the above is the most likely cause.
