Blow-By
Ryan
03-17-2002 17:25:11
I've got a '38 B that has some blow-by that comes out the belt pulley when the pulley is engaged. I can't remember, was it 2-cycle engine oil you can put in the gas to try to seal it up or do I have to put new rings in? Thanks for your help,
Ryan
Clooney
03-17-2002 17:38:16
 Re: Blow-By in reply to Ryan, 03-17-2002 17:25:11
Ryan, you can try a little 2-cycle oil in the fuel tank but I doubt it will seal the rings enough to stop the blow-by.
~When blow-by gets bad enough to come out at the clutch area it usually means piston ring time.
~It probably wouldn't hurt to clean the breather element & make sure the breather tube between the intake & governor is open, but if there isn't any problems there, it's back to the rings.
Ron
03-19-2002 06:36:28
 Re: Re: Blow-By in reply to Clooney, 03-17-2002 17:38:16
I would work it for a good while... We have a "B" that always seems to "Breath" a lot when idleing, but under load, it is just fine, and pulls an 8' JD disc, cultipacker, and harrow in 3 rd gear all day...!! ( 1952, Gas ) I had always understood that there is a vent at the clutch.....!!!!! !! May be you let it idle with the clutch drum not turning, and the "Slinger" can't work to keep oil in, if it isent turning... ( just a guess)... If ours are the least bit over-full of oil, they will "sling oil" at the clutch drum...
Ryan
03-18-2002 16:46:05
Clooney,
How much 2-cycle engine oil should I put in the gas? Thanks, Ryan
Clooney
03-18-2002 17:28:07
 Re: Re: Re: Blow-By in reply to Ryan, 03-18-2002 16:46:05
Ryan, you can try about 6-8 oz per tank-full but I doubt it will stop the blow-by..
