Ditributor question and wireing too
Jack
03-17-2002 06:39:52
My 53 G distributor is turned down to where the plug wires are pointing at the right spark plug.It runs ok but why is it turned downward and not straight ahead like the 52 G I have?I have seen a few like this and was wondering whats up with that.I also need a wireing diagram for the 12 volt positive ground system for a G.Thanks,Jack
Clooney
03-17-2002 07:52:09
 Re: Ditributor question and wireing too in reply to Jack, 03-17-2002 06:39:52
Jack, while there could be a few reasons that your distributor is turned too far, such as incorrect initial timing, stuck advance weights or bent parts. The usual cause is the governor not indexed to the crankshaft correctly therefore not allowing the distributor drive flange to be in the correct position (slots parallel to the ground with the L/H piston at TDC). I presume you have a Delco distributor?
~Check your E-mail for "G" wire diagram..... .
