Woody, Went through this about two months ago. light tapping with a hammer did not work. Resisted the urge to tap more than lightly, but the consequenses were too great. The next steps were: PB Blaster applied and soaked overnight = no success Heated cast iron ear to a dim red color = no success Waited a day and heated the bolt to a dim red color = no success Used a pneumatic impact chisel with a point on it = no success Tried a two jaw puller (that wasn't really made for this exact application) = no success Welded a nut to the threaded end and tried to turn the whole bolt = no success Cut off the threaded portion at the ear and drilled progressively larger holes in the clutch bolt about 1" deep. Put another 3/8" bolt in the hole in the clutch bolt, and tapped on it while applying heat to the cast iron ear = success I noticed that on the new clutch bolt there are some splines. These splines seem to cause an interference fit into the cast iron hole. Quite a bit of force was required to install the new bolt. One more note. I purchased the split bushing from JD that is in the parts catalog, reamed out the clutch arm pivot hole, and the whole mechanism is now like new.
