Hi Jim, as the temperature drops, the batterys efficiency lowers PLUS the old girl is harder to crank over, making it a double whammy. If she cranks too slow, heres how I would proceed: 1) Make sure the battery is well charged. Maybe place a charger on it a while before attempting to start it and then see if she cranks better?? If so, you might check out the charging system and battery. Is there electrolyte above all the plates and no cells have a gray or milky color??? You could take it to a shop and have it load tested??? If you substitute another known good battery or jump it, does it crank better??? On 6 volt systems, I prefer heavy duty high amp hour and Cold Crank Rated CCR batterys. Light duty batterys may not perform sufficient as themperature drops. This first paragraph was to check the battery performance before proceeding. 2) On 6 volt systems, I recommend the use of 00 Gauge battery and starter and ground cables. What are yours??? 3) Even though you say they are good but its so easy to do, I would remove, clean and wire brush, and re attach all the battery terminals and starter and ground connections. 4) Nowwwww w if the battery is good, well charged, and all connections are good and it dont help, next thing I would do (if you have cable length or try a longer cable) is run the ground cable either to a new place where its attached direct to a solid frame member versus any sheet metal or tin. Best place is on a bolt as near to the starter as possible. 4) If that dont help and the battery and connections abd cables are all good, I would disconnect the battery and remove and inspect the starter switch. If it or the post out the starter is burned badly or pitted or carboned up, THAT COULD BE THE PROBLEM. If the starter switch contactor is badly pitted or burned or carboned up, replace it. If the post out the starter is badly pitted or uneven or carboned, you might first try to clean it and light file it smooth and try it again, but if too badly uneven or worn or pitted excessively, it may need replaced. 5) If all that is good, the starter may still need attention like brushes or the commutator smooth and insulation segments undercut and no shorts in the armature. 6) Finally, if ALLLLL that is good, is she timed too fast??? If timed too advanced she may be kicking back at the starter when cranking. Take a look at where she start fires or retard it or see if she cranks better with plug wires removed. Post back or e mail [email protected] any questions, let us know what happens. Good Luck and God Bless ya Jim John T
