D Pistons
Tony M
03-16-2002 18:21:19
Would anyone know a good place to find some oversize D pistons, preferably with a higher compression ratio? I have a '29 that needs to be bored and will need pistons, and a '37 that I hope to build into somewhat of a puller. With all the D's built it is strange I can't find a source for pistons. All help appreciated.
Clooney
03-16-2002 19:30:17
 Re: D Pistons in reply to Tony M, 03-16-2002 18:21:19
Tony, those "D" pistons are really getting hard to come by & when found cost about as much as the tractor, oversized are even more difficult to locate.
~I usually just sleeve the "D" & use the pistons that come out of it, the ring lands tend to wear on the "D" & sometimes I have to machine the ring grooves wider & use a wider ring.
~I just called for sleeves the other day & they are also becoming hard to find for a 6-3/4" bore, so if anybody has a good source of 6-3/4" sleeves please let me know.
